Hi Friends,
Auto = 1988 Ford Bronco II with an expansion valve type AC system; no orifice metering tube and no liquid line tube orifice at the condenser bottom. We have a slow downturn in AC performance now with 80* F duct air at 100* F ambient, 15% RH. I'll sort out if the heating system is fighting the AC, but for now, I need some smarts on how to bench test the expansion valve. I can blow through it at ambient temp. I can chill the coil in ice water salted down to 10*F progressively and still blow through it. I tried heating the coil in hot water, heating and chilling the valve itself and all combinations of coil and valve body temperatures and it still stays open . . . . but . . . so does a new one. Hmmm. I guess I don't catch how it works then. Unless freon (R134a) pressure pre loads the little spring inside and the cooling coil / diaphragm set up fights it back based on temperature coming out of the evaporator. I Googled trouble shooting tips and found nothing for the valve.
FYI, the low pressure was 35 psig, the high side about 250 psig at 100*F, duct temp about 80*F, compressor suction pipe warmish, compressor discharge pipe very hot (so it is compressing then), condenser discharge warmish, inlet to dryer warmish, dryer itself very hot (???), evaporator outlet warmish (compressor suction pipe). Putting in a touch of R134a from a 30# cylinder caused low side to go up to 38 psig, high side to climb to 275 psig +/- and duct temp to drop to 65*F, however putting in a touch more R134a caused the low side and the high side to spike to 150 psig (L) and 350 psig (H), so I backed off and drained it down. There is no 'black death' in the pipes, compressor seems sound (no crud and rotates free) all piping, evaporator, tubes, hoses, etc clean and unblocked. The dryer is slightly resistive when I blow through it but flows good.
I'm most interested to find out the working of the evaporator valve. I know what it does, but why can't I duplicate it on the bench with 10*F water on the little coil.
What gives? Thanks in advance for a reply.
