Previous in Forum: Why More Current Carrying when Motor On Load   Next in Forum: Electrical - Motor
Electronics
08/17/2007 3:31 PM
What is Diff Betn Half Wave & Full Wave Rectifier
TARGET - Where many stop thinking, some start from there. Tenacity to get target helps to WIN.
Re: Electronics
08/17/2007 4:00 PM
A half wave rectifier is one diode, the half of an AC waveform which is above 0 volts will be conducted through the diode .The negative half cycle will not.
A full wave (bridge) rctifier is usually* 4 diodes arranged so that both positive and negative half cycles will be conducted resulting in both half cycles appearing on the output as positve voltages.
I'm sure if you search the web you will find nice diagrams of this.
(* A centre tapped transformer and 2 diades can also produce full wave rectification)
Re: Electronics
08/30/2007 2:53 PM
Del the cat has a good reply
Register to Reply 2 comments
You might be interested in: Rectifier Diodes
