Previous in Forum: Displacement ventilation for Hospitals   Next in Forum: Airlogistic
compressor
08/18/2007 2:27 AM
what is the compressor full load test?
United States - Member - Woohoo Engineering Fields - Mechanical Engineering - New Member
Re: compressor
08/21/2007 9:38 AM
Without more clarification of where you came up with the phrase I would have to guess that it is the performance of the compressor at full load. So you would be measuring HP and CFM at the rated pressure. Basically it should be a verification of the dataplate info or a test to generate the data plate info.
Hope this helps.
Self-motivational quote: "If they can make penicillin out of moldy bread, they can sure make something out of you." -- Muhammad Ali
Reply to Forum Thread
