Previous in Forum: Ideas for Load Testing a Motor   Next in Forum: Cam Shaft Questions
Shear Strength Nylon Screw
08/20/2007 7:30 PM
I am trying to find the size nylon screw with a shear strength of 200 pounds or the closest to but not over 200 lbf. I think it must be about a size 8-32, but I'm not sure. Also, I would like to know what the shear strength is for the correct size. Can someone out there help?
Thanks,
Steve
Re: Shear Strength Nylon Screw
08/22/2007 12:32 AM
I have never had a 200 lb Screw if you get an address please POST it as soon as possible for us all.
08/22/2007 2:42 AM
hi Steve,
there are even Nylon screws to connect train rails. I don't have it in front of me, but companies as Continental in Monaco, or injection molders near Lion , in France, have a selection of such screws.
reg
Pes
Good Answers: 94
08/22/2007 4:48 AM
You would have to be very careful in specifying a nylon screw, the strength that you measure, as with any plastic, will be dependant on the rate of loading. The screws, even if strong enough, may be susceptible to creep.
United Kingdom - Member -
08/22/2007 5:55 AM
Hi,
Here's a link to a UK company site with the info you need
http://www.anixtercomponents.com/images/uploads/Nylon_screws_strength_data.pdf
I hope this is of some help
Drew
08/22/2007 10:48 AM
This site was perfect. Thanks. Steve
08/22/2007 9:06 PM
"Can someone out there help?"
Properties for Fasteners 200 Learn all about fastners including nylon screws.
Very educational. OTOH you may have to go to a trial and error approach to determine size for you application.
Register to Reply 6 comments
ad016 (1); Anonymous Poster (1); Nigh (1); pesboro (1); sda1950 (1); Stirling Stan (1)
