Hi. Pls help. I got some stuborn water stain on SUS430 snd SUS340 standard steel due to our Aqueous Washing have some problems. I tried removing it with IPA and acetone but it won't be remove. I tried 10% HFL mixed with DI Water in 1.25 ratio. It can be removed but the process is not so simple as i need to apply it very fast ane evenly to maintain the colour of the steel and i need to rinse it to remove some chemicals and soak it again and then rewash the part. And i have thousands of parts affected. So im asking for help it anybody knows some checmical which may able to remove the stain without affecting the surface of the steel? Thank You so much..
