Previous in Forum: Fiber Optics for Household Lighting   Next in Forum: Incinerating Garbage
Hyundai Elantra - Code P0715
08/21/2007 9:08 PM
I did a OBD scan on a Hyundia elantra and got code P0715 Input turbine/speed sensor A circut malfunction. What does this mean in english. Is this a sensor on the trans?
Re: hyundia code P0715
08/22/2007 7:06 AM
What does the manufacturer's manual say about it?
Re: Hyundai Elantra - Code P0715
08/22/2007 11:30 PM
Replace the sensor and flush the trany erase the code if it comes back you will pretty well know the trany is going south on you and time to trade up. Good luck.
08/23/2007 12:45 AM
The Turbo-charger speed pickup is most likely to be the culprit.
The problem started when the lock-nuts become loose, and the sensor shift its position. The proximity between the sensor tip and the magnets is only about 3 mm. The worst case is the magnets hitting the sensor tip, which has coils of fine copper wires embedded in a plastic mold.
The magnets if knocked out of shape or misplaced need to be replaced, and the entire turbo-charger balanced. To this extent, it will be better to get a new turbo-charger.
OBE Code reader has to be verified, but a physical check at the turbocharger can easily tell if this is reading correctly.
tijit
Deut 25:15,16 Honesty in dealings is to God's desires, and dishonesty is His detests.
Register to Reply 3 comments
Anonymous Poster (1); pilotcraig2001 (1); tijit (1)
