Previous in Forum: Let's Get Geothermal: Water Temperature and Pressure   Next in Forum: Tempertaure and Vacumm
Nanoparticle Silver
08/22/2007 4:39 AM
hi,
can any one tell me how to prepare nanoparticle silver from silver nitrate???
thanx
Re: Nanoparticle Silver
08/23/2007 9:40 PM
Have you tried pumping a silver nitrate solution through copper tubing? You can vary the flow rate, concentration and tube length to tailor the particle size. Silver nano particle are behind much of the magic of photoactive glasses. But you'd need to work with molten silver nitrate. What particle size range interests you?
08/28/2007 8:04 AM
i am using AgNO3 solution
will the method you have said will work with the solution???
size of the nanopartidcles doesnt matter.
thanx a lot
Register to Reply 3 comments
Anonymous Poster (1); prateek_nitdgp (1); Serenity (1)
