Previous in Forum: CFD   Next in Forum: hybrid for two wheeler
continuosly variable transmission
08/24/2007 4:32 PM
can i add gear system to a cvt controled transmission , cvt are not fuel efficient, am planning to add gear ratio of two at the drive wheel this will be manually adjusted
Re: continuosly variable transmission
08/25/2007 8:22 AM
"can i add gear system to a cvt controled transmission , cvt are not fuel efficient, am planning to add gear ratio of two at the drive wheel this will be manually adjusted"
Y not? What are the advantages
Y? What are the disadvantages?
What is the cvt in/on?
08/25/2007 8:41 AM
You would have to add this after the final drive/out put. Gear Vendors has "over" and "under" drive units for specific and custom applications.
Register to Reply 2 comments
