Previous in Forum: Vehicle Hydraulic Lift   Next in Forum: Hard and Soft Torque
X-Y Adjustable Locking
12/01/2005 8:41 AM
Danny writes:
How do you call or where can I find info on devices that enable attachment and change angle between two aluminum parts in 90 degrees from each other.
The angle change is done when force is applied.
Thanks.
Perpendicular angle plate
12/02/2005 12:28 AM
Hi Danny, Can you be more specific about what you are trying to set up and do? I worked as a machinist for about 15 years. In that trade they have both adjustable & fixed angle plates for bolting work pieces to. The most common fixed ones are 90 degrees. V blocks are also fairly common for working with round stock. Good luck, DougRH
"‘Mathematics is the language with which God hath wrought the Universe.’ Ancient Greek Mathematician_-_ CKUA.Com 'Eclectic music at its very best!’
Reply to Forum Thread
