Previous in Forum: Replacing 30 kw motor with 60 kw motor in plate bending m/c   Next in Forum: hydraulic power pack
Forming of round emboss
09/03/2007 12:03 AM
Is the above forming of a round emboss feasible to manufacture?
The material formed is commonly used galvanised steel.
Is there any design rule or general guideline when creating such forming?
mikekhoo
Re: Forming of round emboss
09/03/2007 5:15 AM
embosses in sheet metal should be a maximum of 3x material thickness with a maximum side wall angle of 45 degrees.
"correct me if I'm wrong, but hasn't the fine line between sanity and madness gotten finer?" - George Price
09/03/2007 11:48 PM
I agree with the jacket; you have too steep an angle on the sidewall. Unless your sheet metal is extremely well annealed, and is of a material that does NOT work-harden significantly during drawing, it will shear/tear before you get anywhere near the desired depth. You need to increase the large diameter to at least 30, preferably 40mm.
Good Answers: 16
09/03/2007 11:59 PM
Even if you try to do it using deep drawing techniques the galvanising will be cracked and need re-dipping. This will probably cause some warping of the sheet metal unless the overall dimensions are not much bigger than the embossing you are proposing.
Make it so.
Register to Reply 3 comments
BlueAussieBoy (1); dkwarner (1); The Jacket (1)
You might be interested in: Tube End Forming Machines
