Many of you will think of replacing the metal halide with LED horse arena lights. What are the rationale behind? Firstly, horse arena lighting is needed to be installed in a harsh environment – dusty, and water splash everywhere. Therefore, durable lights in horse arena are vitally important for long life span. Durable means that it should be water-proof. It is because sometimes we need to clean the lights by water jet. The luminary is made of strong aluminum alloy and thus it tolerates strong impact.
Then, LED is a much energy-saving light source. LED arena lighting for horse stadium have lighting efficiency of 130 lm/W, you can compare this value to metal halide, it has only around 75 lm/W. Therefore, you can almost get the same brightness but use lesser energy.
Instant on & off of LED lights. In the past, the metal halide takes 5-10 minutes to warm up and cool down, which is very time consuming. However, it is not the case of LED lights. Due to the different working principle of LED lights, once the power is turned on, the lights can be emitted immediately.
Extra life span of the arena lights. Surely no one wants to replace the lamps so frequently. With the use of quality lamps, you can have 80,000 hours to 90,000 hours life span, which is 8 to 9 times of that of metal halide.
For much info, you can get access to
http://www.ledsmaster.com/led-horse-arena-light-261.html
