Previous in Forum: Drought prediction   Next in Forum: Tay Bridge Disaster
The Feature Creep
Leaning Tower of Sioux Falls
12/05/2005 9:29 AM
Over the weekend the demolition of the 202 foot tall Zip Tower in Sioux Falls, South Dakota, didn't go as planned. The explosive charges didn't level the structure as intended. Instead, the abandoned feed mill settled into it's foundation after losing the first few floors. It is now leaning precariously, and has become a make-shift tourist site. Check out the video of the failed demolition.
"The future is here. It's just not widely distributed yet." -William Gibson
Friend of CR4
That's not an engineering failure
12/05/2005 9:38 AM
It's a demoltion failure! I'd say it's an engineering success!
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
United Kingdom - Member - New Member Hobbies - Model Rocketry - New Member
Is the explosives expert really an expert?
12/05/2005 1:13 PM
I have no explosives training, nor do I work with concrete, but this quote from the explosives teasm leader just doesn't seem correct:
"He said the tower didn't fall because the concrete on the west side did not remain stiff. Instead of cutting a wedge out of the east side, the explosion collapsed both sides as well as the basement foundation, leaving the building stuck like a cork in a bottle."
If the concrete didn't remain stiff wouldn't the whole thing have cracked and collapsed when it fell into the hole?
The yoke a man creates for himself by wrong-doing will breed hate in the kindliest nature . . .
Re:Is the explosives expert really an expert?
12/06/2005 11:21 AM
Apparently, the shock of the initial explosion softened or "fluidized" the foundation on both sides. The original intent was to cut the supports out of one side only. The west side was to remain rigid and support the west half of the building as it fell to the east. This should have sent the building tumbling to one side. Since both sides collapsed at virtually the same time the building fell straight down and did not topple to the east. In essence it was jammed into the basement like a cork in a bottle!
Register to Reply 3 comments
Anonymous Poster (1); Chris Leonard (1); Silas Marner (1)
