Previous in Forum: How to Select Glossmeter?   Next in Forum: Replacement Handmade Lamp Shade Supplier from China
Silicon Carbide Ceramic Bulletproof Plate
05/08/2018 10:18 PM
Sintered silicon carbide (SiC) ceramic is a new kind of bullet-proof ceramic material, with low density, high strength, high hardness, high temperature resistance, oxidation resistance, corrosion resistance and other excellent performances. Now it's the preferred general material for bulletproof ceramic pieces, mechanical seals, sand jets as well as magnetic pumps, shielding pump components, etc.
We produce sintered silicon carbide ceramics taking high purity sub-micron silicon carbide powder as raw material, through the spray granulation, pressure molding and high temperature vacuum sintering. As the structure inside is compact, small grains, bullet-proof performance of this product is superior. The breast armor plates made of silicon carbide from our company have reached the standard NIJ0101.06III,IVand passed the grade IIIV bullet-tests held by National Bulletproof Equipment Testing Center for many times. Furthermore this product has successfully passed the target test certificated by the PLA. Nowadays the PLA troops are equipped with this ceramics composite armor.
Our company can produce various specifications of the sintered silicon carbide bulletproof ceramics, and has successfully developed large& whole plates with single-curved surface of bulletproof ceramic.
The products specifications are as follows:
Product appearanceQuadrilateral pieces(mm)Hexagonal Pieces
(mm)
(Across Flats)
whole plates with single-curved surface (mm)
Plane sizes50*5088683020300*250
Thickness5-20mm6-10mm
NotesProducts can be produced according to customers' demands of particular sizes.
http://www.fuboon.com/silicon-nitride-ceramics/112-hexagonal-silicon-carbide-ceramic-bulletproof-plate.html http://www.fuboon.com/silicon-nitride-ceramics/113-square-silicon-carbide-ceramic-plate-for-bulletproof-.html
(mm)
(Across Flats)
http://www.fuboon.com/silicon-nitride-ceramics/111-high-density-si3n4-bulletproof-ceramic-vest-plate.html
www.fuboon.com,ceramic pump,precision ceramic balls,ceramic knives,ceramic tube,ceramic discs,all fine ceramic products.
Pathfinder Tags: Bulletproof Plate
