Previous in Forum: AI Spontaneously Re-Creates Brain Activity Pattern Used in Navigation   Next in Forum: Boston Dynamics' Atlas Strikes Again
AstroSoM: The Sound of our Universe
05/10/2018 3:20 PM
The idea behind AstroSoM is to map raw astronomical data to sound, rather than chart or picture, so visually-impaired people can experience it. Truly the music of the spheres, so to speak.
Re: AstroSoM: The Sound of our Universe
05/10/2018 5:19 PM
This reminds me of Hatnote Listen to Wikipedia, but more rhythmic and musical.
Both are great for background "music" on your PC.
05/11/2018 10:59 AM
I hadn't heard of the Hatnote application. Thanks for the info -- I'll give it a go this weekend. I'm looking forward to sharing both sites with some musical friends!
05/11/2018 11:48 AM
I've used a program called Spectrogram that does the inverse. It takes a sound file and turns it into a visual display. It basically takes an audio file, uses a fast fourier analysis to break it into frequencies and then displays with time on the horizontal axis and frequency on the vertical. One of the things they did with it was to create sound files that would draw pictures.
05/11/2018 3:50 PM
That's pretty slick. I tried it one time with some simple line drawings, but the results were disappointing (horizontal lines were hard to generate).
You might be interested, I surfed around and found this:
http://www.ultimaserial.com/UltimaSound.html
I suppose you could use this as a fax if you had a lot of bandwidth to spare.
A blind person probably could not learn to recognize a picture by its equivalent sound, unfortunately.
Register to Reply 4 comments
BestInShow (1); Jpfalt (1); lyn (1); Rixter (1)
