Previous in Forum: US Navy Railgun   Next in Forum: Robotic Warehouse for Grocery Shoppers
21 comments
Sources for M7 (Metric) Hollow-Lock Set Screws?
05/14/2018 9:29 PM
Greetings Y'all,
So recently I have been looking for a reliable supplier of M7 hollow-lock set screws, also known as jam screws, but it seems that no companies make metric hollow-lock set screws, let alone ones with an M7-1.00 thread. Has anybody come across any good sources for these?
Thanks,
VIXIVIXIV
Good Answers: 145
Re: Sources for M7 (Metric) Hollow-Lock Set Screws?
05/14/2018 10:58 PM
I don't have a clue but that is an interesting little hardware item. I never knew they existed.
05/14/2018 11:05 PM
05/15/2018 12:10 AM
Not bad. I don't know if ordering from them specifically will make sense (50,000 minimum order at a minimum price of $0.001 each, or $50 minimum), but that looks like a promising lead that I'll investigate further during daylight hours.
05/15/2018 1:12 AM
Well, you didn't say how many....haha, don't think you can beat that price...
Canada - Member - New Member
05/16/2018 8:46 AM
How many indeed. If MMC doesn't list it, it isn't very common.
Never stop learning
Good Answers: 225
05/15/2018 3:22 AM
M7 is an unfortunate size for you as it is not commonly available in many ranges.
Why does it need to be hollow? It's not as if you can do anything with the lower screw once you insert the lock.
There are plenty of M6 or M8 short length set or grub screws available that you may be able to use in lieu.
Failing that, and depending on quantity, you may have to purchase longer M7 set screws and part them off in a lathe.
I do this for odd ones that I require, I use a short piece of 2" round stock with a bottomed out hole threaded to the size required and a smaller through hole that allows the key to pass through to loosen the screw after parting. It's a quick process to turn down a few but may be too time consuming if you have lots to do.
05/15/2018 11:26 AM
That's an interesting thought. I might end up doing that if I just want short set screws, but hollow set screws would be preferable because they let light through.
That said, they might sell longer hollow set screws in M7, which I could part down to the desired length.
Good Answers: 151
05/15/2018 2:05 PM
If it is possible, you could re-drill and tap your holes for a standard 5/16-24 UNF set screw.
7mm is .275" diameter. The tap drill for 5/16-24 is .272" ( an "I" drill)
05/15/2018 5:37 PM
That is something that I considered. However, I don't believe I currently have a 5/16"-24 tap or time to get one. Additionally, the higher major diameter would require extra drilling and making the piece weaker than I would consider acceptable, while the 7M-1.00 tap drill is basically a 1/4" hole which already exists in my design.
Good Answers: 151
05/15/2018 6:45 PM
A standard 5/16-24 tap will be easier and cheaper to come by than the non standard M7 setscrews that you are looking for. However, I can't judge the effect that the extra 1mm. in hole diameter would have on your design.
By the way, if your design already incorporates a 1/4" hole, which is actually to big for an M7 X 1 (6mm = .236" is the correct tap drill) it is just right for a 5/16-18 UNC tap.
05/15/2018 7:01 PM
Hmm. Looking at a tap and drill calculator, 1/4" corresponds to a 50% tap for M7-1.00 and about an 87% tap for 5/16"-18. Considering that I'm working with mild steel for this project, tapping for 5/16"-18 will definitely be a pain, but I feel like it's not insurmountable. I suppose I'll have to take a look at CAD just to see if there will still be enough material left after the tapping.
Thanks for the info, though. I assumed that a 5/16"-18 tap would be much more challenging.
Good Answers: 42
05/15/2018 11:22 PM
05/16/2018 3:13 AM
Although, as already indicated, M7 is not very common, you could try https://de.misumi-ec.com/vona2/detail/221000551578/
05/16/2018 10:07 AM
Fastenal carries them. You can get any screw type available from Fastenal. They also carry a lot of other things as well.
05/16/2018 10:16 AM
I did check Fastenal for hollow-lock set screws, but like most hardware distributors, they don't carry them in M7-1.00.
That said, see @gringogreg 's posts. I think I'll go with some kind of 5/16 jam screw instead, assuming that I can find the tap in the machine shop today.
05/16/2018 10:52 AM
If they don't carry them then they will have them special made for your orders. They have their own machine shop too.
Good Answers: 151
05/16/2018 12:22 PM
If you can't find a tap in your shop today (5/16-18 is one of the most common sizes), you can order it from what ever source you buy your set screws from: McMaster, Fastenal, etc.)
By the way, don't be afraid of tapping mild steel. It is one of the easiest materials to tap. Just buy good quality taps. The most expensive tool in your shop is a cheap tap!
05/16/2018 11:01 AM
Try Bayou City Bolt, Houston, TX. They are the go-to source for the Houston Oil, Gas, Petrochem and Pipeline industries. They may have to special order them, but if your set screws are to be found they probably can do it.
FYI: proper Texas spelling is yu'al, and when speaking to a crowd the preferred tense is all-yu'al.
Good Answers: 153
05/16/2018 6:28 PM
Schrauben-Profi from Germany are offering stainless steel, 10mm long, M7 hollow-lock set screws (in Europe we call them grub screws) on Ebay (Ebay seller No 109224)
05/16/2018 7:40 PM
Have you tried to contact Grattan. I go to a local store, The Bolt Bin, in san Jacinto. To buy s.s. 1/4-20 button cap screws and set screws. I use the button screws to replace the inferior mild steel Phillips head screws and the set screws for some sheaves.
Dave Grattan & Sons, inc. www.grattanproducts.com
05/16/2018 8:55 PM
A few updates:
Apparently, the original McMaster-Carr link is no longer functional, and as such here is the updated link. I don't know if this one will continue to function due to the way that McMaster-Carr's website works, but fingers crossed.
I think I'll use a 5/16"-18 jam screw, as it is more readily available, and it turns out that I do have the proper size tap. If I have time, I'll try to finish what I was working on and put up some pictures, but it doesn't seem likely that I'll be done this week.
Register to Reply 21 comments
BruceFlorida (1); Gert Mengerink (1); gringogreg (3); GW (1); Janissaries (2); jhhassociates (1); Kevin LaPaire (1); SolarEagle (2); spades (1); Stephen Archer (1); tonyhemet (1); VIXIVIXIV (6)
