Previous in Forum: Lab mixer for sealant   Next in Forum: Threading Standard
how to use tapper lock bushes
09/14/2007 9:45 AM
hi ,
this is aman from india, student of mechanical engineering pls tell me that how i use a tapper bush for sprocket & shaft
Good Answers: 143
Re: how to use tapper lock bushes
09/14/2007 11:42 AM
Hi Aman,
This link says it better than I ever could.
http://pt.rexnord.com/customer_support/technical_information/quadrive.asp
The "trick" is to make sure you watch tolerances, surface finishes, and torque limits.
12/22/2008 10:08 AM
if yr sprocket is dia 120 & yr shaft is 25 mm , u can use fenner taperlock no - 1610 having dia 65 mm X 30 long.
for that u have to make the sprocket also suitable for 1610 bush. means u make taper hole in sprocket + two threading to lock + one hole to open the bush.
if u require more data pl call 9825088388
