Previous in Forum: Lost or Miss-represented skills   Next in Forum: optical flat
Building codes on HVAC
09/15/2007 11:27 AM
Where can I find building codes on HVAC? Is ASHRAE the correct one?
Re: Building codes on HVAC
09/16/2007 12:06 AM
Yes, you can find codes to design H.V.A.C system In Ashrae
09/16/2007 12:36 AM
ASHRAE has developed standards which are referenced by nearly all local building codes for the design and installation of HVAC systems. You should check your local building code to determine the exact standards used.
09/18/2007 9:44 AM
Refer to the International Mechanical Codes. Part of the International Building Code. I believe NFPA has a competing code, more Union friendly, that California has adapted.
Register to Reply 3 comments
bashar1807 (1); Howetwo (1); OLD F**T (1)
You might be interested in: HVAC Services, HVAC Controllers, HVAC Ductwork
