Previous in Forum: Synthetic/non-synthetic oil compatibility.   Next in Forum: Oxygen Needed To Burn 1 Litre of Petrol
paint quality test procedures
09/16/2007 3:44 AM
Can anyone help me what are the testing methods for checking the quality of powder coating paint.For example refrigerator body,domestic appliances etc.
Canada - Member - New Member
Good Answers: 11
Re: paint quality test procedures
09/16/2007 11:34 PM
Look at www.gardco.com, they sell the equipment used fot testing, with reference to standards.
There are many physical aspects to test.
Their 69th birthday catalog privided me ennough information to answer your question!
Seriously, it is very complete and informative.
09/17/2007 7:52 AM
You have to be more specific or selective when you say: I want to do QC test.
Do you have detailled coating specification spelling out test methods and pass/fail critreria?
What is important for you and your customer in term of performance? it will dictate the test you want to do.
ASTM (American Society For Testing And Materials) is a scientific and technical organization formed for the development of standards or characteristics and performance of material, products systems and services. They produce tons of testing procedure and standard; you have to choose first what you want to check and then apply the standard procedure you need.
For example, if I want to check a refrigerator or an oven coating I would like to check the gloss and color variation from batch to batch against my standard. Then I would check the film hardness, the adhesion, if the paint can resist to domestic cleaning solution, the ease to clean, resist to ketchup, Coke, mustard etc... You got the idea...
On the other hand I want to check a tank lining for a hot water tank my frist criteria would be: NSF-61 approval, service temperature resistance, holiday testing, etc...
Then you have to, how to read, interpret, and use them (ASTM Standard) for meaningful results (different tests and results from each suppliers sometimes).
Your technical sales representative should give you a hand in putting together a QC manual (the usual industry testing method) and standard method book or if you can go to a third party... Depending on what you have done yet I can give you guidelines or go to the entiere process with you...
Hope this help... Oherwise let me know I will try to be more specific...
09/27/2007 10:57 AM
I want to know the procedure for testing powder coating quality like
gloss test,adhesion test , impact test , hardness test, pencil test etc.
kindly help
Best regds.
09/20/2009 3:49 AM
by coating thickness
by wet film thickness
by humidity testing through Dew point meter
by Bresle test
temprature etc
02/01/2011 5:07 AM
Australian Standard 1580 "Paints and Related materials - Method of Test" sets out most if not all the tests that you could possibly do on powder coatings.
Things I'd be looking at are:
Type and density of defects
Thickness (average and range)
Gloss
Distinctness of Image
Solvent Resistance
Stain Resistance
Pencil Hardness
T-bend cracking
T-Bend Adhesion
Reverse Impact adhesion
Scratch resistance
Abrasion resistance
Colour match (in terms of batch to batch, in terms of thickness, and in terms of cure)
Humidity resistance
Acid resistance
09/26/2009 9:29 AM
Self administered questionnaires were used to assess the painter's experiences of working with different types of paints and the occurrence of symptoms in the exposed and unexposed groups. Hygiene measurements were performed during normal working days when only water based paints and no solvent based paints were used. The painters were exposed to low concentrations of dust, metals, ammonia, formaldehyde, and volatile organic compounds. The work environment was considered better when working with water based paints than with solvent based paints. There were more complaints of frequent urination when working with water based paint. Taste or olfactory disturbances were less common. General as well as work related eye and skin irritation was more common among the exposed workers. For other symptoms no significant differences were found. The study indicates that the introduction of water based paints has improved the work environment for house painters. Water based paints cause less discomfort and airway irritation than the earlier solvent based paints. Adverse general health effects seem low. Some of the painters may have dermal symptoms caused by the components in water based paints.
02/06/2010 2:34 AM
Yes, Sure...
Please call me +9198227 52450
0r write to
paintfinish@rediffmail.com
Meghan Manjrekar, Pune India
I am a Consulting Paint Technology
Register to Reply 7 comments
Anonymous Poster (1); gigaconcept.com (1); Madmax1997 (1); mahtabsir (1); Meghan Manjrekar (1); wahid212 (1); Yowie9644 (1)
