Previous in Forum: Software   Next in Forum: Current Unbalance in Three-phase Induction Motor Under No Load
Register's Location
06/09/2018 11:37 PM
Im learning embedded system , after reading a lot of book but i still dont figure it out where is the register of microcontroller .It inside the processor or another hardware, i still dont know. Cant you guy help me. Thank you.
Re: Register s location
06/10/2018 12:06 AM
06/10/2018 3:42 AM
Registers are all inside the processor part of it's architecture.
Basically all a processor can do is move numbers or bits around, subtract, and compare bits, and move numbers in and out of other hardware.
It just does it very fast and all the other functions are just variations on this.
06/10/2018 5:57 AM
For example ,in arm cortex processor, i thing there are 2 place register could be , one is bank register or memory interface. Cant you tell me where exactly all register could be... thank you
06/10/2018 11:29 AM
Get the data sheet for the processor. Only the chip manufacturer can answer this question.
What I fail to understand is why you need to know this. I see it as only relevant if you are programming in the processor's machine or assembly language.
06/10/2018 11:43 AM
Re: Register's Location
06/10/2018 11:42 AM
Registers are on the microprocessor chip.
There are various kinds of memory the microprocessor can use. Registers are very close and quick to access, but there is limited space on the chip. Other memory types are slower to access but have higher capacity. It's a tradeoff of speed versus size, so all different types are used.
"There are four major storage levels.[1]
  1. Internal – Processor registers and cache.
  2. Main – the system RAM and controller cards.
  3. On-line mass storage – Secondary storage.
  4. Off-line bulk storage – Tertiary and Off-line storage."
https://en.wikipedia.org/wiki/Memory_hierarchy
06/10/2018 2:43 PM
Register to Reply 7 comments
redfred (1); Rixter (1); SolarEagle (3); trungsave96 (1); user-deleted-1105 (1)
