Previous in Forum: The Rotary Pulse Jet Engine: New Concept in engines.   Next in Forum: PLENUM in an HVAC System: What Does it Do?
piston ovality
09/16/2007 1:22 PM
how to calculate piston ovality and what is the formulae.
what is single double postive ovality?
please make it clear
Re: piston ovality
09/16/2007 11:29 PM
"how to calculate piston ovality and what is the formulae."
Measure maximum and minimum diameter and compute the ratio.
Single - Doulble Ovality
Good Answers: 247
Re: piston ovality
09/17/2007 12:22 AM
This link will give you the formulas for single, double, and triple ovality.
Re: piston ovality
08/24/2009 6:57 AM
Blink the link you gave can not be reached. Could you please upload it if you have it.
Re: piston ovality
09/17/2007 5:51 PM
it's my understanding that the purpose of the ovality is for the piston to expand to roundness as it achieves operating temperature
If you always do what you've always done, You'll always get what you've always had!
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
Re: piston ovality
09/18/2007 2:44 AM
That's what I think. However, I have seen competition pistons, I can't think of the make right now; but they are the really slimline ones, that are supposed to be as near perfectly round as they can get them. Of course, they don't have a great lifespan....
'The truth is out there' The lies are in your head.
Re: piston ovality
09/18/2007 10:53 AM
Room for expansion is accomodated by the ring gap. The primary reason pistons are oval is that because there is a small amount of flip flop slop in the motion around the piston pin. An oval shape tilted in the bore will present a circular aspect to the top of the cylinder. Thus, you will have a more circular face presented to the cylinder forces for the majority of time during both compression and power strokes.
When a motor is severely overheated the pistons will lose their oval shape and the subsequent loss in power is easily detected on the dyno. In this case the opposite effect occurs. During compression and power stroked the forces see an oval shape in the bore and the increased leakege results in less power.
Re: piston ovality
09/23/2007 7:42 AM
thanx for the response ya its true thge ovality is the difference between the major axis and the minor axis and it is provided to attain the circular shape when the piston is their inside the engine.but i want to get the details about the double positive and double negative ovality and can some body make this clear with details along with some data on symmetrical profile and un symmetrical profile.
Register to Reply 7 comments
Anonymous Poster (1); Blink (1); honey1 (1); PlbMak (1); serdar_akkoyunlu (1); sidevalveguru (1); Stirling Stan (1)
