Previous in Forum: DELTA FERRITE IN SA 335 P92 STEEL   Next in Forum: Hydraulic Oil Temp
DC Generator
06/15/2018 1:32 AM
Please guys am kind of stack with this question, be of help please...
A short shunt compound generator delivers a load current of 20A at 250V and has armature series field and field resistance of 0.025, 0.15 and 250Ω respectively..calculate the induced EMF and the armature current, graphite brushes used have an appreciable voltage drop
Re: DC Generator
06/15/2018 1:38 AM
You can work this out with the proper equations....this should help
http://www.drhenrylouie.com/uploads/23-DC_Generators_part1.pdf
Re: DC Generator
06/15/2018 11:00 AM
WebMath - Solve Your Math Problem
You should read the FAQ's:
  1. Are there specific rules for posting?
  • Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider the following and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other academic assignments is to help you learn - by practice, repetition, and self-discovery.
Re: DC Generator
06/15/2018 12:08 PM
Look here:
lyn (1); Rixter (1); SolarEagle (1)
