Previous in Forum: Concentricity of a D Fork in a Knuckle Joint   Next in Forum: Pulley vs Sheave???
Momentum Versus Impulse
09/18/2007 7:12 AM
What is momentum and what's the effect of impulse on momentum? If the momentum of a system will be changed what might have happened to the system (it's velocity, mass)? What is the reason for rebouncing the thrown ball on the floor after hitting it?
Re: momentum Vs impulse....
09/18/2007 7:16 AM
Re: Momentum Versus Impulse
09/18/2007 10:49 AM
mv=ft or momentum (mass x velocity) is equal to impulse (force x time). Maybe a little reading on 'dimensional analysis' would carify?
Wish I was here more often.
09/19/2007 12:38 PM
Strictly speaking, FxT=∆MV (deltaMV, in case it doesn't show correctly)
09/20/2007 9:57 AM
Yes, of course, apologies.
09/21/2007 10:51 AM
hello friend,could u tell me why specifically (deltaM)....is it change in mass??why we have to take so....
09/21/2007 12:15 PM
Not delta M, but delta MV.
∆(delta) preceding any quantity, as you seem to already know, means 'the change in' the following quantity.
MV, the product of mass and velocity, is called momentum, which is a measure of the tendency of an object to keep moving with the same velocity (meaning both speed and direction). When an unbalanced force acts on an object, it accelerates (changes the speed and/or direction) of the object. The final momentum of the object is the sum (vector) of the initial momentum and the change in momentum caused by the impulse.
A good example is launching a satellite. The launching rocket gets the satellite up to the orbital altitude, but if that is the only force, the satellite will just fall back down to Earth. A small orbital insertion rocket must then burn (exert a force) for the correct time to increase the velocity of the satellite to the higher value required to stay in orbit at that altitude. The product of the force and time of burn of the insertion rocket is the impulse of the rocket, which changes the already considerable momentum of the satellite to the higher value required to stay in orbit.
Once in orbit (assuming a circular orbit), Earth's gravity exerts a force of constant magnitude but constantly changing direction, of the correct value to keep changing the momentum (again constant magnitude but constantly changing direction) of the satellite, so it's velocity is always perpendicular to the line between the center of the satellite and the center of the Earth. Here the time may be less than obvious. If you choose a time equal to half the orbital period, the net effect of all the little impulses (like the impulse exerted by the Earth each minute, for example) exerted during that half orbit is to reverse the direction of the satellite.
Hope this helps...
Dick
Popular Science - Weaponology - Chronic intel collector
09/23/2007 3:57 PM
What is momentum
Momentum is the product of the mass of the body and the velocity with which it is moving
This sould give you a fair idea
Momentum and Impulse Connection
In case of the change of momentum of the system, either the mass or the velocity or both mass and velocity of the system may change
The ball rebounds because of change in direction of velocity of the ball the moment it strikes the surface. This change in momntum caused by impulse.
Get busy living.... Or get busy dying - The Shawshank Redemption
Register to Reply 7 comments
Anonymous Poster (2); dkwarner (2); slugger (1); Wrenched (2)
