Previous in Forum: Pulley vs Sheave???   Next in Forum: Hertz Contact Stress
Sanitary Double Tube Heat Exchanger Stainless Steel 316 L Needed
09/18/2007 1:06 PM
I have a client in the Mid East looking for a sanitary standard heat exchanger, the information supplied is:
"Sanitary double tube heat exchanger Stainless steel 316 L with the following specification:
- The heat exchanger will be used to cool down distilled water from temperature of 90 oC to 15 oC with a flow rate of 60 liter per hour, inlet and outlet connection are 1 inch try clamps.
- The cooling media is child water ( inlet temperature= 8 oC, max. outlet temperature= 13 oC).
-The heat exchanger must be isolated and cladded with a 304 Stainless steel cladding."
Anybody know of a quality assured supplier in the UK or Europe?
Re: Sanitary Double Tube Heat Exchanger Stainless Steel 316 L Needed
09/18/2007 3:10 PM
Let me Introduce me , we areinto import and eport business, we can get you what you are looking for " Sanitary Double Tube Heat Exchanger Stainless Steel 316 L"
send me your detailed requirnebtto my followingmail ID jaydomnic@rediffmail.com & tejasincorportion@gmail.com
Waitngfor your detailed requirment andwecanQuote you our best price
Thanking you
for Tejas Incorportion
jairaj.panikar
09/19/2007 1:15 AM
Try these people for a second hand unit.
http://www.labx.com/v2/newad.cfm?catID=422
09/19/2007 11:13 AM
You may want to consider a flat plate heat exchanger. They are available in double-walled construction as well.
http://www.flatplate.com
Check out the DW series.
09/19/2007 4:29 PM
We are a designers and fabricators for process Shell-and-Tube heat exchangers in accordance with ASME BPVC and TEMA.
If you accept that type -shell and tube- send me your detailed specifications to include Heat Exchanger Data Sheet to my e-mail : abujalala2005@yahoo.com
Thanking you
Register to Reply 4 comments
Abdel Halim Galala (1); Brave Sir Robin (1); JAIRAJ (1); SloopJohnB (1)
