Previous in Forum: Cool New Bike Drive Train   Next in Forum: Hard Rock...Any Guesses?
12 comments
Strut Tower Repaint
07/17/2018 11:41 AM
Continuing the rust mitigation process on My 2008 Mustang GT...The strut tops were cleaned using an abrasive wheel, SS wire mini-brush and coated with a rust remover...
I neutralized the rust remover, which is actually just acid, with some baking soda and water solution, and dried it off....
Then I coated it with por15 top coat, 2 coats, and then primer, 2 coats, and then factory matching red paint, 2 coats...Will allow this to dry for 30 days, and add another 2 coats....
Re: Strut Tower Repaint
07/17/2018 1:27 PM
Are the strut towers such a particularly effective rust engine that all that is necessary?
On the other hand, a painful enough process that extra care is probably warranted.
07/17/2018 1:51 PM
It's a Ford... Enough said.
I am currently and have driven Fords my whole life. I live in the rust belt. I have seen shock/strut towers rust to the point of catastrophic failure.
I think the prevention he is doing now could save him a lot of headache later down the road.
JMHO.
07/17/2018 1:56 PM
Probably not, but these are the main mounting points of the body to the suspension for the front of the car....and I'd like to test this procedure to see how it holds up...There are some items I'm just replacing and some I'm restoring....I just replaced the rack and pinion steering and inner and outer tie rods....and had the wheels powder coated....
07/17/2018 2:24 PM
I like the fact that you are doing this work yourself.
It's the only way to be sure what, actually, was done.
Good Answers: 137
07/18/2018 5:43 AM
You've done the easy bit , but are you sure there is no rust on the underside of the mountings?
07/18/2018 10:53 AM
I'm not sure of anything....but I'll cross that bridge when I come to it....I'm a ways away from having to dig that deep to find problems to fix....haha
07/19/2018 12:33 AM
Good question. I was thinking that myself.
While SE may not have to deal with slush and road salt, the salt air is pretty rough on cars.
Good Answers: 137
07/19/2018 3:44 AM
Yes, when there is rust on a car it's usually coming through from the other side.
But having said that, I've no idea what the underside of my strut mountings is like either! Next time I have the wheels off I'll take a look.
07/19/2018 10:47 AM
That's not the case here, the salt is not coming from being splashed up, it's from the ocean spray from above and horizontal....There's a big difference from being even a block away from the surf, to being just 100'...as I found out....This was just surface rust that took place over a few years, prior to that the car was garaged and pristine...
07/19/2018 11:48 AM
Another good reason to live in the desert.
07/19/2018 12:53 PM
There's more than one?
Good Answers: 137
07/19/2018 5:01 PM
OK just a thought
Register to Reply 12 comments
Casper71 (1); Codemaster (3); Doorman (1); JPool (1); lyn (2); SolarEagle (4)
