Previous in Forum: API 650 Material Groups   Next in Forum: Engine LO Consumption
Applications Of Modern Gears
07/24/2018 6:14 AM
let’s take a look at some of the industry specific applications of modern gears.
  1. Marine industry:
The gears utilized as a part of this industry are typically termed to be marine gears. Such gears not just facilitate major power transmission, but also high speed. 2. Earth Moving industry: Gears such as helical, spur and planetary happen to be an integral part of the vehicles and machinery utilized as a part of the earth moving industry. 3. Defense industry: Gears are basically utilized as a part of this industry in different sorts of weapons and additionally in different components necessary for the correct operation of this industry. 4. Power Generation industry: Gears assume an essential part in making most of the power generation equipment functional. This is one industry that sees a wide range use of planetary, bevel and internal gears.
Pathfinder Tags: mechanical gear applications
Good Answers: 70
Re: Applications Of Modern Gears
07/24/2018 5:40 PM
What is your point? Are you advertising for CRB Tech? Or just amazed at where you can find gears in modern equipment?
09/26/2018 8:03 AM
Gears are used for several reasons:
  • They serve to keep the turning or rotation of two axes together.
  • Gears can increase or decrease the speed of rotation and can easily be used to reverse the direction of rotation.
  • Another reason gears are essential is that they transmit rotational motion to a different axis.
Register to Reply 2 comments
