Previous in Forum: Differential pressure driven pneumatic switch   Next in Forum: Mountain Bicycle
Location: Lenox, Massachusetts, United States of America
Blade Wear and Usable Life
12/22/2005 4:33 PM
We just received this question from a friend and posted it in hopes of getting some help for him:
I recently rented a floor cutter with a diamond blade on it. I noticed when the guy picked out the blade for me to use he picked out one that was the most worn. I was thinking at the time that he was giving me the worst one because he was going to give me a break on the price of the blade wear. It was a 14" blade. I noticed the blade was worn to where the carbide sections were worn past the steel disk on which they are attached. I've noticed in the past that when a blade would reach that point, it wouldn't cut very well and would spark and get hot; pretty much what that blade did when I used it. I was wondering when is a blade considered unusable or worn out?
The reason I am asking is because when I returned the cutter the guy measured the blade again and he tried to charge me $180.00 blade wear charge. I wouldn't pay the charge so now he's taking me to small claims court. So I' m writing to see if anyone can tell me when is a blade considered worn out, so I'll have some ammunition for my defense.
Any helpful information that you can provide me with will be much appreciated.
Friend of CR4
An interesting dilemma
12/22/2005 4:44 PM
I don't know off hand but I'll do a little research tonight and try to find some concrete information for you. I'd also suggest that you fully research any leads that someone here puts out for you instead of claiming it as specific expertise. Judges generally prefer documentation to opinion.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Re:An interesting dilemma
12/23/2005 8:26 AM
Sorry to here your in this kind of situation. I believe this rental place is gouging you. Once a blade is worn past the "cooling slots", it is concidered to be trashed. This man is a decietfull and dishonost business owner. Most shops that rent this type of equipment usually charge everyone who uses their equipment a nominal charge for blade wear over the "life span" of such an item. He probably has been charging most people a small fee and figured he could screw you into this payment. You should have baulked at the blade from the beginning. Or at least taken some pictures and measurements. I have been involved in the construction business for many years, and once a blade is past the cooling slots, it was trashed and a new one was purchased. Anyhow, this shop owner has a five year wright off with his taxes for armorization of his assets. He probable wrote the blade the first year he purchased it, or at least 70% of the life. Go to all the concrete construction groups you can and get a writen letter of general practice concerning this type of equipment. On most blades sold, the manufacture has wear lines marked on it and given the suggested life span. Once the diamond surface is worn off, it is concidered trashed. if the man measured the blade before he gave it to you, and then measeured it when you returned it, then you are pretty much screwed. You on returned, should have measured the blade your before and after you used it. Then you could have some type valuable resource to fall back on. Plus, if you did not use enough water to keep the blade cool and the dust down, you brought it upon yourself. Don't mean to rain more on your problem. Good luck
12/24/2005 11:36 AM
the saw had a hose attachment and I'm sure I used plenty of water.Thanks for your response RS
12/26/2005 4:32 PM
If the cintered carbide teeth are gone, this is no longer a usefull or safe blade to rent to anyone. The wearyou get charged for is how many thousands of an inch you consume of the teeth. If what MillMatt says is correct they don't have a leg to stand on. My grandfather used to say,"things slide alot further on bullsh_t than on gravel."
I love this site.Thanks to everyone that makes it possible.
blade ware
12/23/2005 3:23 PM
go to a different rental and please tell everyone you know what a ripoff they are and may be we can get rid of these low life companies.good luck in court....
Anonymous Poster (1); Chris Leonard (1); Grant (1); jay (1); LordMaximo (1)
You might be interested in: Blade Servers, Relay Sockets, Saw Blades
