Bottom drain line in an in-ground swimming pool. The bottom drain in our swimming pool was abandonded and cemented over with hydraulic cement several years ago when we replaced the pool liner (it was about 15-20 years old at that time and really needed to be replaced). The pool technician told us at that time that the drain was cracked and broken and the reason for abandoning the bottom drain was the fact that in our area, they were illegal to be installed in brand new pools being installed due to the danger of small kids having the potential for drowning if their hair or soft body tissues were to be sucked into or against the intake grill by the suction of the vacuum of the main drain inlet from the bottom of the pool. The main drain has been cemented over and a new pool liner was installed over it. However, the 1 1/2" ABS line that was/is connected to that same abanded bottom drain (1 1/2" black ABS) still comes to the main skimmer intake at the end of the pool. My dumb stupid sister who lives at the house sometimes takes out and removes the rubber stopper which is the only thing that is stopping the opening to the ABS pipe to the bottom drain. Hence, we lose an enormous amount of city water down the drain into the ground until someone notices that my stupid dumb sister had removed the rubber stopper and didn't bother to tell anyone what she did. Is there any way, that I can make a permanent plug stopper to that bottom abandoned drain so that if my stupid dumb sister in the future, does happen to remove that stopper to the bottom drain again (inevitible). Does hydraulic cement poured into a funnel and flow smoothly down into the 1 1/2" ABS pipe in order to displace whatever water is existsting in the line and will it properly set with same water?
