Previous in Forum: JP-7 Fuel Alternatives?   Next in Forum: Destruction of Cyanide
Desulfuration Calculations
09/24/2007 1:25 PM
HI
Our company got a good contract to make 10 steel ladles. But I got a problem in design.
The company wants to desulfurate and calculate the possible volume produced in the ladle to add more capacity in the ladle. Does anybody know about this stuff.
The ladle capacity= 150 ton, we need to calculate the volume produced when you are desulfurating in order to calculate the extracapacity in the ladle.
Israel Barron
ibarron@sfmex.com
www.promsa-mva.com
Israel Barron ibarron@sfmex.com
Good Answers: 120
Re: Desulfuration Calculations
09/25/2007 4:39 AM
what is the ladle, a cylinder with a spherical end with a pair of trunnions and a bottom attachment to allow cran suspension and tipping? What is the density of the bottom layer and the layer above it? How much free space is needed above the metal and flux layers? Volume of the 1/2 sphere bottom is easy, volume of the cylinder part is easy. Hot strength of parts is a problem? Is there a refractory lining?
Per Ardua Ad Astra
Good Answers: 243
09/25/2007 9:22 AM
Israel I'm travelling today, but will try to get back to youthis evening.
Freeboard for turbulance from the reaction is likely to be the more important factor, than additional volume. What is the desulfurizing reagent that will be used? Calcium carbide? Magnesium Wire? if the sulfur from you iron is even half a percent, that will not lead to much volume when chemically removed by the reagent. So the turbulence will be the design factor. As well as how it is to be injected.
milo
09/25/2007 11:10 AM
I would like to suggest to hire a Metallurgical Engineer. Getting rid off a good deal of Sulphur is a routine in the Steel Making process.
Register to Reply 3 comments
aurizon (1); Milo (1); siegenjolu (1)
