Previous in Forum: Design Challenge: Improve Paint Booth Hooks   Next in Forum: Designing Own Engine
16 comments
Treatment for Cutting Tool Shanks
08/28/2018 3:33 PM
Does anyone know a company that sells a system to apply a chemical treatment to the shank of a cutting tool to eliminate or minimize tool pull-out?
Re: Treatment for cutting tool shanks
08/28/2018 3:37 PM
08/28/2018 3:46 PM
Sorry, but I didn't find anything about a shank treatment in your link. Harvey might certainly be using such a process, but back to my question. Are you aware of a company that sells such a system?
08/28/2018 4:39 PM
08/28/2018 6:31 PM
Thanks. I'm familiar with this Safe-Lock, but that requires safe-Lock holders. We're using shrink fit
08/28/2018 4:06 PM
https://www.commandtool.com/assets/uploads/general/affiliate_flyers/Helical_Pull-Out_Flyer.pdf
Nice fancy patented name but it looks like a light sand blasted profile to me. A light blasting on a polished shank would certainly increase the friction.
08/28/2018 6:29 PM
Thanks. That looks like what we're after. But our tech guys think it's more of a coating than a sandblast. What do you think?
08/28/2018 6:49 PM
Could be a zinc phosphate coating.
08/29/2018 10:28 AM
Thanks! I'll look into that!
08/28/2018 7:38 PM
Could be ESD....
..."Carbinite is a tungsten-carbide alloy that can be applied to most metals using a process called electrospark deposition (ESD), yielding a true metallurgical bond. This high bond strength far surpasses any spray-on coating currently available. Carbinite can be used as an alternative to spray, thermal, or diamond coatings in many applications.
Need a sample? CLICK HERE."...
http://www.carbinite.com/
08/29/2018 10:32 AM
Thanks SolarEagle!
This could be a good option. I'm sending for samples.
08/28/2018 5:56 PM
The problem is that you have a hardened, polished jaw (or collet) gripping a hardened, polished shank. Not much friction there.
I don't know if knurling a shank and sand blasting a collet, or sand blasting both, would help, but it might be worth a try.
08/28/2018 6:25 PM
Thanks. For now, we're sandblasting, while we look for a better technology. But thanks again for your response
Re: Treatment for Cutting Tool Shanks
08/29/2018 7:51 AM
08/29/2018 10:35 AM
Thanks
But we're using carbide plain shank tools and Rego's method would require flats. Good option otherwise.
Thanks again
08/29/2018 10:22 AM
Put a little lapping compound on the shank. The grit will increase the friction and it can easily be cleaned off.
08/29/2018 10:38 AM
Thanks. But we're looking for more of a mass production process
Register to Reply 16 comments
JPool (2); lyn (1); SolarEagle (3); SteveA15 (8); wrenchtwirler (1); XNuke (1)
