Previous in Forum: Drum Motor Problem   Next in Forum: Micom P545
9 comments
Micom P545
09/06/2018 1:56 PM
Hi
I am trying to connect to a micom P545 device via a switch over a 61850 protocol.When I ping the connection is okay but on attempting to connect I get an error " cannot open port"..
What could be wrong here?
Re: Micom P545
09/06/2018 2:05 PM
Re: Micom P545
09/07/2018 9:55 AM
Do you have the Logical node identified properly?
phoenixcontact.com/2016/03/what-is-iec-61850
Do you have the correct baud rate? Some devices will show up but not properly communicate if the baud rate, data bits (7 or 8?), parity, flow control, and stop bits are not configured correctly>
https://www.gegridsolutions.com/app/ViewFiles.aspx?prod=P543&type=3
MikeMack747
Re: Micom P545
09/08/2018 1:00 PM
In all other cases Where I have communicated to IED's under IEC 61850, after defining the IP addresses, communication is established. By the way, I can communicate via a serial port but have failed on Ethernet IEC 61850 via a switch.
Re: Micom P545
09/07/2018 10:26 AM
The communication error to be precise is C32CS
Re: Micom P545
09/07/2018 1:55 PM
https://www.schneider-electric.com/en/faqs/FA233393/
The above is a good troubleshooting guide
MikeMack747
Re: Micom P545
09/07/2018 1:56 PM
Try closing the port, then reinitializing to the correct communications settings
MikeMack747
Re: Micom P545
09/11/2018 1:56 PM
Are you certain a switch is what you need here?
black-box-explains-ethernet-hubs-vs-ethernet-switches
MikeMack747
Re: Micom P545
09/12/2018 1:58 AM
Not that I need a switch but it is convenient for me to use i as I do not have to physically shift from relay to relay to configure. Connecting directly to the IED through the front port has no problem
Re: Micom P545
04/15/2019 9:58 PM
Hey Richard,
Did you find a way of solving this problem?
I am facing the same problem and until now i cant resolve it.
I have tried to install a newer version of S1 and also have used another computer but i get the same error everytime.
Register to Reply 9 comments
Anonymous Poster (1); MikeMack747 (4); Richard Matsiko (2); SolarEagle (1); walaceferreira (1)
