Previous in Forum: Prototype/Production   Next in Forum: Amazing and Unique Exterior Designs Ideas
Solenoid Valve
09/16/2018 9:53 PM
Solenoid valve - The structure and operation principle of the solenoid valve
Taiwan cheap genuine Taiwanese electromagnetic valve, the opening and closing valves used by electromagnetic force.
1. What is a solenoid valve?
Solenoid valve is an open-close valve used for electricity. Electromagnetic valves are used in a wide variety of industrial, civil and industrial fields ... most widely used in the fields of pneumatic and fluid ...
2. Classification solenoid valve:
With the development of automation technology today. Electromagnetic valve is an increasingly used device. The electromagnetic valve can be classified as follows:
Classification by market (conventional type):
Inverters are made of stainless steel
Flanges for water, oil ...
Technical specifications of the electric valve from the flange:
- An electromagnetic valve that can be used for water, oil, acid.
- Material: stainless steel, cast iron
- Use voltage 24VDC, 220VAC
- Temperature of use: -5 - 80 degrees Celsius
- Design of two flanges with dimensions from: DN50, DN 65, DN 80, DN 100, DN 125, DN 150, DN 200, ...
- Pressure: 8 - 10 bar
- How it works: There are two types of closed and usually open
= LH: 0989 347 503 for more information about the valve solenoid valve
Electromagnetic valve from US
Electromagnetic valve fitting lace
Specifications:
- Structure of 2-way valve with threaded connection with pipe size: phi 13, phi 17, phi 21, phi 34, phi 42, phi 49, phi 60 ...
- Material: brass, stainless steel, plastic ...
- Electromagnetic valves can be used for water, oil, acid, steam, compressed air ...
- Use voltage 24VDC, 220VAC and 12VDC
- Temperature of use: There are two types of temperatures are usually -5 to 80 degrees Celsius and high temperature -5 to 185 degrees Celsius.
= >>> http://auvietco.net/van-dien-tu/
Pathfinder Tags: Solenoid Valve van dien tu
Re: Solenoid valve
09/16/2018 9:56 PM
What is gate valve? >> http://auvietco.net/van-cong/
Re: Solenoid Valve
05/06/2020 11:08 PM
baoviet2702
Re: Solenoid Valve
05/26/2020 7:11 AM
Thanks for sharing the link.
Re: Solenoid Valve
05/19/2020 3:12 AM
baoviet2702
Re: Solenoid Valve
05/21/2020 7:29 AM
very well explained. Thanks.
auvietco (1); baoviet2702 (2); msbettyhunt (2)
