Previous in Forum: SMED   Next in Forum: Future of Gallium Arsenide Laser
Bonding Chrome Plating to Zinc Die Cast and Aluninum Die Cast
09/26/2007 12:14 PM
I am wondering which material, Zinc Die Cast or Aluminum Die Cast, Chrome Plating would bound and adapt to better. Say if the part is going to be used in an outdoor grill.
Re: Bonding Chrome Plating to Zinc Die Cast and Aluninum Die Cast
09/26/2007 1:26 PM
The Grill:
Zinc tasts like Lizard Dung, I would not use that.
Aluminum causes Memory loss sounds bad to me.
Chrome Plating will come off in the first few uses, so why use it.
Answer un-asked for:
A baked on Ceramic coating is pretty good
Stanless Steel works just fine
Just plain steel is OK also
A rule of thumb, do not use things that will not take the heat
Do not use things that tast bad.
Do use things that are easy to clean up.
09/26/2007 11:55 PM
Chrome plating is given for Zn die casting as Al has its own oxide coating may not need chrome plating
Good Answers: 94
09/27/2007 4:53 AM
Vitreous enamel is good if the part is not too thin.
Good Answers: 94
Re: Bonding Chrome Plating to Zinc Die Cast and Aluminum Die Cast
03/12/2009 5:17 AM
Is this part going to be used in the flames? I hadn't really thought of this before but we had a fire recently in the equipment store used for my spare time job staging firework displays. An 8ft long aluminium spar used for Catherine wheels completely melted leaving just a few blobs of solidified metal. The fire was mainly burning timber, I imagine that charcoal burns hotter.
Register to Reply 4 comments
angelopc (1); dbdwoods (1); Nigh (2)
