OK - here's a question:
Suppose I have an electronic component on a printed circuit board, and suppose that component is dissipating some power - not enough that I would bother to add a heat sink, but enough that it's temperature increases, say 10-20 degrees (C).
Now, supposed that I needed to paint that component with white spray paint. Actually, let's say it's two components, one a black plastic component (a rectifier bridge) and the other a package that's part black plastic and part shiny metal (a TO-220 power transistor).
What effect does the white paint have on the temperature of the device?
The tiny bit that I remember from thermo in school is that the more reflective the color, the less emissive the material. So - it seems like white paint on a black component would cause the component to heat up, while white paint on a shiny metal component would cause the component to cool off, slightly.
Assume that we're talking about a thin coat of standard spray paint - not a thick latex paint or conformal coating, in an enclosure with still air.
OK, now let's add a complication. Suppose the circuit is driving a 10W xenon lamp which is a few inches from the components. Now, the question is how does the paint affect the absorption of the lamp heat by the components. Presumably it will keep the black components cooler, but allow the shiny metal components to gain a little more heat.
Which is the greater effect - preventing dissipated heat from leaving the parts or preventing radiated heat from the lamp from warming them?
It's things like this that keep me up at night.
Not really - but it is a question I need some insight on.
