i have a question regarding the calculation of stresses on busbar in low voltage switchgear due ti short circuit currents.
assume the height and thickness of parallel bus bars, for example is 1 bar of 1/4" x 4" per phase, in a 3 phase system with the bars parallel to one another with the 4" sides facing:
there is an article which details calculation of forces " #162 electrodynamic forces on busbars in lv systems", the artical wa published by merlin gerin and identified as the cahier technique.
the artical seems to indicate that the forces are directly proportional to "dwght's constant". this constant is represented in a chart. the chart indicates that:
a. the farther the busbars are away from one another, for a given dimension of busbar, the greater are the electrodynamic forces.
b. the smaller the dimension of the facing sides of the busbars with respect to the thickness of the busbar, the greater the electrdynamic forces.
do you feel that the above is correct, or do you feel that the formula was mis-stated in the article, and the relationships should be inversely proportional?
i would appreciate it if you can respond.
thank you.
