Previous in Forum: Flowrate to Drive DC Motor?   Next in Forum: Wiring for a tub with spa jets
Connecting the shield of signal cable
09/26/2007 11:11 PM
I have seen two methods for connecting the shield of signal cable, (1) connect one end of shield with ground (2) connect one end of shield with 0V of power supply. Which is the better way?
Re: Connecting the shield of signal cable
09/27/2007 12:23 AM
I depends on what is connected to it. The equipment manufacturere will avise the method with the equipment
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
09/27/2007 2:07 AM
Both can be done , this depends on instrument configuration.
the cable has 2 cores or three wires or only one core.
one core, you have to connect shield layer to ground and the ground connects directly to po9wer supply ov and earth. unbalance structure
2 core, you can let the shield layer suspending.(empty, link to nothing) at another terminal, the shield layer links to ground. balance structure
3 cores, pin1 link to ground, a nd pin2,3 link to signals. sometimes, these two wires have 12v or 48v voltage to supply device like phone power. now the shield can connect ground or suspending. at another terminal link to ground.
Do read manual to prevent from faulty.
Good Answers: 61
09/27/2007 8:41 AM
If the power supply 0V is earth grounded, the two methods are functionally identical.
However, if the power supply is floating (all outputs ungrounded), or connected to earth ground through a resistor or other limiting component, you must connect the shield directly to earth ground.
Register to Reply 3 comments
cnpower (1); coconutpete (1); pwr2thepeople (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
