Previous in Forum: Can Attachments be Welded on a Knuckle Region?   Next in Forum: High Altitude Dredging Operation
Bending and Hoop Stresses-Cylinder
10/20/2018 1:34 PM
How do we combine bending stress on thick walled cylinder from external point load or moment to other longitudinal, radial and hoop stresses which are from pressurized thick walled cylinder. Since bending stress and longitudinal stresses are in the same direction, I can add those, but what about bending and hoop stress or if hoop stresses significantly higher than bending stress, can i just say cylinder is critical for hoop stress and write margin against that.
Cylinder is both loaded internally by pressure and external load.
thanks
Re: Bending and hoop stresses-Cylinder
10/20/2018 4:40 PM
As long as you are in the linear region, you can add components. Once nonlinearity sets in (e.g. buckling) all bets are off.
"The Principle of Superposition is a method used to solve complex problems with multiple loads and/or reactions acting on the member. Superposition helps us solve these problems by breaking the member down as many times as necessary for each force acting on it. Once all the stresses or deflections for the point of interest are found, they can then be added all together to get a final answer."
http://www.engineeringwiki.org/wiki/Principle_of_Superposition
10/20/2018 10:48 PM
Typically vonMises stress formula is used to combine longitudinal and hoop stresses in pressurized cylinders. Longitudinal stresses are axial and bending. Pipeline codes address this for example ASME B31.8. Only limitation is that basis is in thin shell theory (i.e. Barlows equation for hoop stress) so when applied to heavy wall problems yields unreasonably conservative results in some instances .
Good Answers: 38
Re: Bending and Hoop Stresses-Cylinder
10/21/2018 10:40 AM
I suggest that you review some of the information available on the development of piping and pressure vessel codes. Specifically you should look for historical development of the Code equations for evaluating stresses.
Remember, the equations incorporated into the Codes are the subjective result of a committee of engineers....
When these Codes were developed compromises were made.
Here are some places to start:
https://www.osti.gov/servlets/purl/4031361
https://www.scribd.com/document/173934962/Companion-Guide-to-the-ASME-Boiler-Pressure-Vessel-Code-Volume-1
Horhey PL Guy (1); MJCronin (1); Rixter (1)
