Previous in Forum: Global Nuclear Waste Management Market   Next in Forum: Touch Of Luxury Villa Exterior Ideas
44 comments
NSF to PST to Converter Tool
11/27/2018 8:20 AM
Use the great third-party tool that is ATS NSF to PST Converter software which shows the preview of recovered mailbox before the conversion of NSF to PST. After the conversion, you can save your data into several file formats such as PST, EMLX, EML MBOX, MSG, HTML, CSV, vCard, vCal. It is workable with all the version of OS Windows like 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). It gives 24x7 technical support for you to the conversion of NSF file to Outlook PST file. To see the working performance you can download its free demo version which allows you to convert 30 emails per folder free of cost.
Read More: https://www.bulkecommerce.com/store/nsf-to-pst-converter-153.html
Re: NSF to PST to Converter tool
11/28/2018 5:26 AM
Softaken NSF to PST Converter Software is 100% safe and secure that allows converting the emails from lotus notes NSF file to outlook PST File. Using software extract every NSF emails, contacts, calendars, task, notes, inbox items, journals and appointments. No compromise to the file quality will be done by the reliable software.
03/27/2019 8:08 AM
If you search on Google about NSF to PST converter tool then you will find a lot of tool in this category claiming NSF files conversion into PST file format. But according to my personal experience, you can try software from a renowned brand such as eSoftTools. Their NSF to PST converter software is also available for free with the demo version and has won a lot of awards for the performance. This is powerful enough to manage the entire process of conversion its own without modifying data in any case. NSF file can be exported into many different file formats such as PST, EML, EMLX, HTML and many others
Know more: http://www.nsf-to-pst.com/
12/30/2019 2:35 AM
Anonymous Poster #2
08/28/2019 2:34 AM
Don’t go for the manual conversion as it will not provide you with safe results all the time. Just go for NSF to PST Converter for reliable and accurate conversion along with multiple benefits that will help you to customize your conversion as per your demands. I personally worked on this tool and suggested it to various users because of its flawless speed.
Visit Now: https://www.osttopstapp.com/nsf-to-pst.html
03/16/2021 9:19 AM
Step I: Export NSF Files to CSV
To export NSF files from Lotus Notes, perform the steps given below
Launch IBM Lotus Notes program.
Click File > Open > Louts Notes Application.
In the Open Application window, browse for the required NSF file and click Open. The selected NSF file gets opened.
Now, on the File menu, click Export.
On Export dialogue box, enter the file name, file location, and saving type.
Select the Comma Separated Value format for the file.
A dialogue box CSV Export gets open. Select the required options from How much to export, Export Character Set and Detail to Incorporate sections. Click OK.
The exported data gets saved in CSV file gets saved in the defined location.
Step II: Import CSV File into Outlook
Import the Intermediate CSV file into MS Outlook by following the steps:
Launch MS Outlook program.
On the File menu, click Open & Export, and then click Import/Export.
An Import and Export Wizard dialogue box pops up. Select Import from another program or file from the options. Click Next.
Select Comma Separated Values as file type and click Next.
Click Browse and select the path for CSV file created earlier using the Export command of Lotus Notes. You can select the options according to your need.
Select the Outlook folder where you want to save your exported data and click Next.
Select the given checkbox in the Import a file dialogue box and click Finish. You can also change your destination or map custom fields by clicking on the same name options.
The data from the “CSV file” would be imported to “MS Outlook.”
More info: Email Migration Service
Regards,
Caleb
Re: NSF to PST to Converter Tool
11/29/2018 8:06 AM
For the conversion of Lotus Notes data into PST file, I suggest you InQuit NSF to PST Converter tool that is famous in this filed. Through the help of this admirable application, you can convert single as well as multiple files in a few minutes without consuming more time. After the conversion you can save your data into PST, EMLX, MSG, HTML, Office365, Live Exchange Server, CSV, MBOX, vCard, and EML file format. This software compatible to export encrypted and password protected file in a little moment without losing any data. it supports 24x7 technical support.
Read More Info: https://www.inquitsoftware.com
01/23/2019 11:30 PM
This program will scan your hard disk for NSF and PST files - you can then choose the folders to select them in the preview: this feature will show you all the folders that the database has found in the selected NSF to PST file, including the email messages contained in them.
Check out more info visit here:- https://www.sametools.com/convert/nsf/
03/27/2019 7:50 AM
If you are looking for a reliable NSF to PST converter tool then try eSoftTools NSF to PST converter software free version. It can work with any variant of Lotus Notes server without taking a long time. A preview is provided to the user of the working mechanism of the software for a better experience. The data is not altered in the process. There is no NSF file size limitation for NSF recovery.
Know more about free NSF to PST conversion ways here.
03/28/2019 2:02 AM
You can use NSF to PST Converter tool if you have NSF database and want to export
03/29/2019 8:45 AM
SysInspire NSF to PST Converter tool is the great option to fix entire corrupted OST file fastly and restore them into PST file. This application gives the most reasonable response for recovering NSF file for example - calendar, contact, emails, notes, task, inbox items, outbox items, appointments, and many more formats. This system gives a facility to see the preview and 24x7 help to deal with every issue of NSF file. With the help of this, you can convert your NSF file into PST, EMLX, MBOX, ICS, EML, MSG, CSV, vCard and HTML formats. It can support Windows operating systems like: - Win2000, Win Server, Win Vista, Win XP, Win7, Win8, and Win10. Supported By Lotus Notes versions like:- 9.1, 9.0, 8.0, 8.5, 6.5 and 7.0.
Try to free demo version and click this link:- https://www.linkedin.com/pulse/nsf-pst-converter-software-olivia-smith/?published=t
04/06/2019 4:50 AM
To Convert your NSF files in bulk into PST format by using the greatest tool NSF to PST Conversion.
06/12/2019 1:54 AM
NSF
12/30/2019 2:33 AM
07/16/2020 5:23 AM
There are no. of applications available online that transfer NSF of Lotus Notes to Outlook PST file format. But I would like to advise you one such most select NSF to PST Converter Software that supports to transfer NSF to PST, EML, MSG, and MBOX Mailbox.
10/26/2025 2:31 PM
Regzion
03/30/2019 6:07 AM
ok.
04/02/2019 3:13 AM
Apart from the above-mentioned NSF to PST converter, Shoviv Lotus Notes to Outlook Converter is another effective solution which provides you to convert multiple NSF files to PST very proficiently. It also exports NSF mailboxes into different formats such as EML, EMLX, MSG, and Html. It supports all versions of Lotus Notes, Outlook, and Windows Operating System. Download its free trial version and check the efficiency of the software. With the help of this trial version, you can migrate the first 25 items per folder.
More details, visit:- Lotus Notes to Outlook
07/30/2026 12:58 AM
I have used SysTools NSF to PST Converter which is also good. Worth buying!
05/08/2019 12:58 AM
nsf to pst converter
09/16/2019 8:21 AM
There are lots of tools available in the market but choosing an ideal tool among them is one of the difficult tasks. I have used the NSF TO PST file exporter and found great results. So, I would like to suggest you this tool. I hope you will also get 100% satisfaction. Lotus Notes to Outlook Converter Tool it is one of the best tools.
More Info Visit Now: https://www.osttopstapp.com/nsf-to-pst.html
03/28/2019 2:04 AM
02/08/2019 12:27 AM
Conversion of NSF to PST:
Step1) Run MS Outlook Application.
Step2) Click on the file menu, Go to open tab and select the import button.
Step3) Import Wizard will appear, Click on import from another file then click on next.
Step4) Choose comma separated value option and then click on next.
Step5) Select the file from the location you have saved earlier and choose your MS Outlook mailbox.
Step6) Click on finish.
09/14/2019 2:14 AM
Save NSF TO PST file to Outlook PST with the help of NSF TO PST file exporter. The tool is specially designed for move in NSF TO PST files. The tool has a great support working on all Outlook versions. I hope you will really like the tool due to its instant result providing facility and reliability Before the conversion work, it displays the preview of recovered mailbox then store the data into many amazing file formats .
Visit Now: https://www.osttopstapp.com/NSF-to-pst.html
06/12/2019 4:22 AM
The most affordable NSF to PST converter tool is eSoftTools NSF Converter Software. This software can recover NSF file which is corrupted and inaccessible. This Lotus Notes file converter can export NSF file into many different file types including MBOX, EMl, HTML, MSG, and many others. A free trial variant is provided to each user for satisfaction. User a view at each every proceeding of the software is provided to each user.
Explore more here: http://www.nsftopstconverter.esofttools.com/
07/30/2019 3:06 AM
There are various methods to convert NSF files to PST but the one that is mostly recommended by experts is using the NSF to PST converter. Great software to migrate Lotus Notes files in Outlook format. It can be used to create a PST file that is compatible with Outlook 2019/2016/ 2013/ 2010/ 2007/ 2003. With a few clicks, you can get the PST file from Lotus Notes NSF.
The email migration tool can export the orphaned NSF to PST format. It has many other features like
  • Quick, Fast and Secure conversion of NSF files.
  • Repair corrupt NSF files
  • Recover accidentally deleted NSF Files without error
  • Options to save file in RTF, PDF, PST, MSG, EML, and HTML format
  • Scan files allow selective conversion
  • Move files directly to Office 365
  • Easy to use and compatible with Windows OS
With so many features NSF to PST converter is the best software for Lotus Notes to Outlook file Transfer.
Read for more information Visit on this website:- http://www.nsf-converter.com/
08/17/2019 4:08 AM
NSF to PST
Effortlessly Convert IBM lotus notes NSF to PST using EdbMails. All your mailboxes from the NSF file can be exported to Outlook PST without any data loss. This PST file can then be imported into Outlook.
Software link :- www.edbmails.com/pages/nsf-export-and-migration-features.html
EdbMails features :-
EDB to PST
Free EDB to PST
Convert EDB to PST
EDB Recovery
EDB to PST Converter
OST to PST
OST to PST Converter
More info visit link :- www.edbmails.com
08/26/2019 3:06 AM
I have a blog where I got an exact solution in NSF to PST migration, So to get the perfect result in MSF to PST conversion follow this blog link:- Convert NSF to PST
12/30/2019 7:15 AM
01/11/2021 2:47 AM
  • To export NSF files from Lotus Notes, perform the steps given below
  • Launch IBM Lotus Notes program.
  • Click File > Open > Louts Notes Application.
  • In the Open Application window, browse for the required NSF file and click Open. The selected NSF file gets opened.
  • Now, on the File menu, click Export.
  • On the Export dialogue box, enter the file name, file location, and saving type.
  • Select the Comma Separated Value format for the file.
  • A dialogue box CSV Export gets open. Select the required options from How much to export, Export Character Set, and Detail to Incorporate sections. Click OK.
  • The exported data gets saved in the CSV file gets saved in the defined location.
To know more about office 365 to office 365 migration or exchange 2010 to 2016 migration, visit O365CloudExperts.
Regards,
Caleb
08/16/2019 2:13 AM
The NSF to PST conversion Utility is the impeccable another to migrate information. For detail, the NSF to PST Converter is available free of cost for the demo. Read More:- https://www.softknoll.com/nsf-to-pst-converter/
09/17/2019 8:01 AM
vMail NSF to PST Converter is an easy to use software and complete Email Migration tool for Lotus Notes (.NSF file) migration to MS Outlook (.PST file). This NSF Converter can save recovered emails and other data from NSF file to PST, EML, MSG and MBOX file formats. NSF to PST Converter supports Lotus Notes 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0 versions of .nsf file and converted PST file supports MS Outlook 2016, 2013, 2010, 2007 and 2003. Learn More-http://www.vsoftware.org/nsf-to-pst-converter.html
09/27/2019 6:25 AM
I would like to suggest you can also try ZOOK NSF to PST Converter quickly migrates Lotus Notes to Outlook PST format. It offers batch export NSF to PST format by converting Lotus Notes NSF to PST format. The utility easily extracts IBM Notes contacts, calendars, email messages, journals, tasks, to-do list, notes, and much more into Outlook PST format without applying any extra efforts. It is fully compatible with all the available versions of IBM Lotus Notes i.e. it supports Lotus Notes 9.0.1, 9.0, 8.5, 8.0, 7.0, 6.5, 6.0, etc.
Read More Info,Visit Here:- https://www.zooksoftware.com/products.html
10/21/2019 6:37 AM
utilize the best tool isKDETools NSF to PST Converter is the best way to convert NSF to PST. The converter supports all Outlook and Windows versions. The software converts only the selected file. It gives free preview before conversion. The software recovers all damaged and corrupted items. The Converter converts the NSF file into various file type in MSG,MBOX,EML,PST ,vCard,vCal,Office365 account, Live Exchange Server, etc. The software migrates
the NSF contacts in vCard format and NSF calendar in vCal format.
Read More: https://www.kdetools.com/nsf-to-pst-converter.html
Anonymous Poster #3
11/27/2019 2:27 AM
Well, there is no direct NSF to PST conversion that is manually available, but you can use the import and export method for migrating Lotus Notes to Outlook in an easy manner. I come by another blog that shared very easy manual ways to convert Lotus Notes file to Outlook PST file in just a few steps. Read the article here:https://wordpress.semnaitik.com/convert-pst-to-nsf-database/
12/14/2019 5:39 AM
Here everybody needs powerful NSF to PST Converter tool, In any case, I would prescribe you before utilizing any tool must attempt manual system for NSF to PST Conversion. Attempt Export-Import strategy to migrate information from NSF to PST. Utilizing this strategy you have to pursue two significant advances, for example, initially export Mailbox of Lotus Notes condition and also import every one of the items to the Outlook.
If Manual conversion not works, at that point you can utilize eSoftTools Import Lotus Notes To Outlook
12/30/2019 4:51 AM
Download the Stellar Converter for NSF software that easily recover lotus notes NSF file and convert NSF file to PST file, EML, MSG, HTML, and many more formats. The software allows convert selective single and multiple emails from lotus note NSF file and restore emails, contacts, calendars, tasks, notes, and appointments. The software also shows the preview of converted files.
01/22/2020 6:02 AM
02/06/2020 9:20 AM
Easy Steps for NSF to PST Conversion
  1. Run the software and click Add Local NSF file(s) to select NSF files.
  2. Browse any number of NSF files.
  3. After you have selected NSF files, click the Preview button to get a glimpse of the selected NSF file data.
  4. View the preview of the selected file item.
06/09/2020 9:38 AM
08/01/2020 9:12 AM
The tool which can be considered as the best NSF to PST Converter tool by the users and experts is eSoftTools Lotus Notes to Outlook Converter Tool. It lets the user export information from various file types such as EML, EMLX, vCard, MBOX, PST, and others. Every single element of the mailbox can be restored with this tool. Even data can be filtered easily for migration with date filters. The user can restore information from this tool without any data loss. A free demo version is also offered to all users with the support to work well with all editions of Lotus Notes.
Get More Info:- Convert NSF to PST
01/13/2021 6:36 AM
Use the third party tool to export the NSF file to PST file format.
04/29/2021 1:29 AM
Users can now smartly export multiple NSF files to various other file formats or email clients using an advanced solution by Data Recovery Solutions (DRS). Check out the outstanding DRS
NSF to PST converter which allows saving NSF files in PST, EML, MSG, MBOX, EMLX, OST, Gmail, IMAP, Yahoo, AOL, etc. It supports all the versions of Windows OS and has a smooth user-friendly GUI. The free version can easily convert 50 items per folder for free.
11/25/2021 8:12 AM
Users can convert NSF Lotus Notes to Outlook PST files by using NSF to PST Converter. software is designed with many updated features that allow users to convert NSF files to EML, EMLX, MSG, Yahoo, Gmail, Office 365, ICS, Zimbra, ICS, VCF, and PST files without any technical difficulties. The easy-to-use interface displayed the live recovery and conversion preview. it also, best Lotus Notes NSF Recovery tool that can regain all data from Lotus Notes such as emails, journals, notes, attachments, contacts, etc.
07/29/2026 2:40 AM
If you're looking for a tool that preserves mailbox data and supports bulk migration without requiring complex manual steps.
The SysTools NSF to PST Converter is a reliable option. It converts IBM Notes NSF files to Outlook PST while preserving emails, contacts, calendars, attachments, folder hierarchy, and metadata. It also supports bulk conversion and wo
Register to Reply 44 comments
annibraun (1); Anonymous Poster (3); briaragard (1); caleb_cruze (2); Christiaabram (2); gimmywatson (2); Irisrose (1); jacksmith (1); jainvertika (1); JamesPorter02 (1); jan smith (1); jennyjohan (1); kellyjohnson1 (2); Kevin Colin (3); Lewis-H (1); mackjohn (1); mariyajennifer (2); mecarle (1); NickRodas01 (1); oceana (1); Owenabram (2); priyankaarya (1); rajat16 (1); rigbrick (1); rosefresh (1); sharmahrsh20yt (1); sobon11859 (1); Sophiaabram (1); tanyabhandari (1); user-deleted-1020 (1); user-deleted-615 (1); user-deleted-748 (1); user-deleted-974 (1); williamus (1)
