Previous in Forum: Cleaning Technology   Next in Forum: How to Weld 'IN 825' Super Alloy with 304 Stainless Steels?
Welding Super Alloy with Carbon Steel
12/15/2018 11:58 AM
Dear Sirs,
We have to weld two solid shafts, each of ~ 250 mm diameter. The shaft materials are IN 713 [Super alloy] & Carbon Steel respectively. Operating temperature of the joint shall be ~ 3000 C.
Please help to suggest the best possible welding technique & welding consumable to make the joint.
DDN VERMA
Re: WELDING SUPER ALLOY WITH CARBON STEEL
12/15/2018 1:44 PM
Cut and paste into a browser. I cant link with Opera.
Improving the Weldability of Ni-Base Superalloy 713C
files.aws.org/wj/supplement/WJ_1982_11_s348.pdf
inconel 713c inconel: Topics by WorldWideScience.org
https://worldwidescience.org/topicpages/i/inconel+713c+inconel.html
12/15/2018 2:46 PM
Re: Welding Super Alloy with Carbon Steel
12/16/2018 9:35 AM
Deposit 3 or 4 layers of hi nickel welding consumable ( wire for Tig , electrode for SMaW) on carbon shaft side).
first layer grind to leave thin depisit. on this layer deposit second layer- grind, third layer or fourth layer will give you high Ni deposit
t hesame as NI alloy. prpare bevel and weld w Ni alloy consumable. keep in your mind that termal expension of Ni and cs are different. pls double check! expect cracks on
12/16/2018 12:59 PM
Besides my previous message I have more solutions for your inquiry. CR4 moderator: removed phone number per CR4 rules. You can use the CR4 email feature to contact other community memjbers. in order to send you scketches and detail welding sequency.
Vladimir
Register to Reply 4 comments
lyn (1); SolarEagle (1); Vladimir Radzinsky (2)
