I managed to rebuild an old ultrasonic welding machine. It is a Radyne FW 1/13 (200-250 volts, 50 cycles, 1 phase).
I didn't know anything about radio-frequency welding before, but I've done some research and I've managed to weld a few plastic sheets together with varying degrees of success.
The head of the machine has a 31cm long part made from brass with screws that is meant to hold other brass beams/bars that will come into contact with the material to be welded. I made some of these bars myself. My research tells me these are called "sonotrodes", but I'm not 100% sure.
I've read that manufacturing these sonotrodes is something that needs to be done very carefully and precisely. That the shape, format and length of these bars is critical to the correct working of the machine. This scared me. The machine is still working okay, are things really this critical?
The objective is to weld semi-transparent vinyl sheets together with an almost invisible seam. I sharpened one of the sonotrodes like the blade of a knife and this is what I'm doing: I place two sheets one on top of another under that "knife" and I carefully remove the excess material during the welding process (if I let the process finish, I'm no longer able to separate the excess material, I just need to be careful not to burn my fingers). After that I open the two welded sheets and I use the same machine with a wider sonotrode to flatten the seam.
This method works reasonably well, but the seams are fragile. I assume there is an ideal sonotrode length to achieve a better result and I'd like some help with this.
Thanks in advance.
