Previous in Forum: Machined cavities in pistons improve fuel economy   Next in Forum: A Quiet Wind Tunnel
Help Needed: A lifting device for a linear rail
01/09/2006 12:46 PM
We have a 10' long linear rail (~100lbs) which will have a 250lb load translating from one end to the other. The lifting device needs to cover a range of 1'6" to 3'6" and remain stable with the load at either end of the rail. Our first choice for operation would be manual (a crank, etc.), second choice would be electric and third would be hydraulic or pneumatic. The weight of the lift needs to be less than 200lbs if it is a single unit or if it is multiple pieces the total weight must be less than 400lbs with no individual piece exceeding 200lbs. If anyone has any ideas or experience on this subject please help. Thank you!
lifting device
01/09/2006 6:42 PM
If you could use a spreader bar and a crane of sorts, this would provide the stabillity you want with equal distribution of the weight. Can you attach slings or lifting lugs or eye bolts? Check out the Crosby website.This company specializes in rigging and lifting equipment and hardware.
I love this site.Thanks to everyone that makes it possible.
Good Answers: 37
Lifting Device for Linear Rail
01/10/2006 10:28 AM
Look into putting a support cable at each end, with EACH cable running over a pulley vertically above its load. Bring BOTH cables to a single winch drum (for a few hundred pounds, manual is more than adequate). If you know how the harnesses lift individual heddles on a loom, you'll understand immediately. Here's an image of it (Google "Loom +harness" and go to page 9) shows just about enough: the bi-color cords at the ends lift each heddle, and pass over pairs of pulleys to meet at the central "Y", where a single down-cord pulls in response to a treadle below. More typically, both cords go to one side and then down, but winch location is something you'll need to decide.
" Ignorance and arrogance have more in common than their last four letters. "
01/10/2006 11:49 AM
The above suggestions are great, but( I failed to mention in the first post) we need to lift from the bottom as our max height must be less than 5'. Thanks for your responses.
Good Answers: 37
Lifting a Linear rail
01/10/2006 5:40 PM
OK: I must still be missing something. Your only "overhead" [pun] is the diameter of the sheave at each end, since it can be mounted on the side of its support and essentially be flush at the top,where the cable turns 90 degrees and parallels the rail. It can turn downward again to the spool, so the winch is beneath the rail, if desired. Imagine a 4' tall sawhorse straddling the rail end-to-end, or a cut-down kids' swing set, with pulley wheels on the top rail near the leg junctions, and the winch mounted on the leg itself. If you still must lift from below, a pair of nuts can be attached to the rail, and threaded rods going through them can terminate in sprockets resting on thrust bearings (top or bottom). Sprockets permit synchronized rotation, hence give level lift (like the table on a wood planer). You'll need to provide guidance, say by trapping each end of the rail within a vertical channel to prevent sideways buckling, if working from beneath. Acme threaded rod and nuts are readily available (www.jlindustrial.com item GNG-82020D, e.g.) - and you WANT acme for friction, life, and strength reasons. A handwheel on the top of one (or both) rods gives manual input for lifting.
Register to Reply 4 comments
Grant (1); npoling (1); Ron (2)
You might be interested in: Lifting and Rigging Attachments, Lifting Jacks
