Previous in Forum: Looking for a pump with the following specifications   Next in Forum: Sump Pit Design
14 comments
"Rubber Shock Absorber"
10/08/2007 1:28 PM
Does anyone know where I can find a rubber shock absorber which would be approximately one foot long and have approximately a 1" diameter with an eye on both ends. It is intended to be fastened in a line with wire rope under tension so that the object being supported on the wire rope is not subjected to severe shock or vibration.
Good Answers: 38
Re: "Rubber Shock Absorber"
10/08/2007 3:52 PM
What is the weight? For safety reasons I would not use a rubber rod with eye bolts. The only thing holding it together would be only as much as the rubber within the threads could hold. There are many shock dampening devices out on the market. Try Google If it's light weight use a spring. Better action and fastening abilities.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
10/08/2007 4:04 PM
Thanks
The weight with safety factor would be about 2500 lbs.
The spring may be an excellent alternative. I have seen the rubber used with a logging chain holding a floating dock and it worked well however I could not find the source.
05/02/2023 4:41 PM
1-1/2" x 30' 74,000 lbs. Slingshot Kinetic Energy Recovery Rope
https://www.amazon.com/Rocket-Straps-Capacity-Reinforced-Emergency/dp/B071R361Q9?th=1
05/03/2023 10:34 PM
Good Answers: 266
10/08/2007 5:56 PM
Try a polyester sling the material has some stretch to it will handle the load.
Good Answers: 114
10/09/2007 12:47 AM
try a bundle of these & add a cable or chain in the middle for safety.
10/09/2007 1:00 AM
I'm sorry, but my experience with Harbor Freight leaves quality pretty far behind...
I certainly agree with the chain or cable in the middle for safety. 2500 lb is a LOT for anything of rubber under tension - compression would be another thing.
Which brings to mind a couple of U-shaped devices compressing a block of rubber - if the rubber should fail, the Us simply become a chain...
10/09/2007 12:58 AM
Check you local boating store. Sound like those used to take the strain off mooring lines for big (over 35') boats.
10/09/2007 1:19 AM
Please send us complete drawing we can provide the product you are looking for.
Do provide complete details and if you have a picture pl mail us at tag_bros@yahoo.com
Best Regards
Naresh
10/09/2007 3:27 AM
Dear Sir,
We are one of the manufacturer of Anti Vibration Mount (Rubber Shock Absorber), we are into these businesss since past more than 35 yrs.
Moreover , we also manufacturers any items from Rubber or Metal to Rubber Bonding items such as Rubber Sheet, Rubber Pads, Rubber Bellows, Rubber Hoses, Rubber Buffers , Gaskets, Diaphrgms, O-Rings etc.as per the drawing / specification or sample of customers.
For more information we request you to visit our website ie www.dynacorpindia.com
We sure that our technical team will solve your problem and recommend you best Anti Vibration Mount (Rubber Shock Absorber). Hence, we request you to give your requirment on saurabh@dynacorpindia.com / dynamics@bom5.vsnl.net.in or call us on 91-22-22871429 / 91-22-22871430
If you have any further quarry please do not hesitate to contact us.
Awaiting your valued reply.
Regards,
FOR DYNAMICS CORPORATION
Saurabh Shah
10/09/2007 9:30 AM
I agree with humpman. Boating stores have rubber shock absorbers that work very well with faily high loads. You do not tie the rope to each end, though. You pass the rope through the eye at one end, wrap it around the rubber and through the eye at the other end. As the rubber straightens, the rope gradually takes the load.
Good shock absorbance, no shock at the end of travel, no loss of strength from knots.
10/10/2007 1:35 PM
Any Large Marine Store.
West Marine, Boat US, Boaters Wharehouse, etcetera.
10/10/2007 2:24 PM
Boats 'R Us? BoatMart? ACME Boats?
05/02/2023 2:51 PM
If you have shared your location that would be convenient. however, we do offer Anti vibration mounts, pads, sheets. https://www.rubbersheetindia.co.in
Anuj K. Jain
Register to Reply 14 comments
Anonymous Poster (2); charsley99 (1); dkwarner (1); Garthh (1); goGreen (1); HarryBurt (1); humpman (1); M Sidon (1); ozzb (1); prbarry (1); SolarEagle (2); TexasCharley (1)
