It is known to most Exchange server administrators that exchange server databases develop corruption issues over time. Gauging the extent of this corruption and its cause as well as seeing as to how all the data can be safely recovered from the Exchange database is what keeps many a exchange administrators busy.
People who have had experienced this before would know very well that the goto solution for exchange database recovery was powershell cmdlets such as eseutil. However, these may not always live upto the expectation and has many limitations.
These days, there is no need to look for complex powershell scripts or cmdlets as there are a lot of utilities available to help you perform Exchange Server Recovery. It also becomes imperative that the utility you select is able to provide complete exchange data recovery without any hiccups along the way.
One such utility is the EdbMails EDB to PST Converter. Why convert EDB to PST? Well it is the easiest way to recover information from exchange database file. It helps recover all your mails, contacts, calendar, tasks, notes etc from even the most corrupted exchange EDB file. No matter how big the size of your Exchange mailbox is, the EdbMails EDB to PST Converter can handle it well.
EdbMails EDB to PST tool maintains the folder structure of the EDB file intact and also lets you preview all the EDB contents before export operation begins. Whats most novel about EdbMails is that its interface is so easy to understand and self explanatory that you don't need to be a technical person to be able to retrieve all the information from your Exchange database file.
Key features :
An extensive filtering option to filter mails by subject, date, to/from address etc.
Public folder EDB migration.
Direct EDB migration to Office 365 as well as Live Exchange Server.
The most demanding EDB to PST converter software is SysInspire EDB to PST converter software. It is a tool which can recoup Exchange EDB file into many different file types like PST, EML, EMLX, HTML and many others. Even large PST files can be broken down into small PST files easily. All variants of MS Exchange server and Outlook are workable with this tool. A free version is available for free to try.
For conversion of Exchange EDB files into PST, EML, and MSG format, I would suggest you try a reliable EDB to PST Converter tool from Shoviv. Using this tool, you will also be able to export repair corrupted EDB files, restore deleted items from EDB files, export EDB to Office 365 and migrate EDB to Live Exchange server.
Following are some different manual methods to convert EDB to PST manually
Method 1: EDB to PST Conversion using PowerShell Cmdlets
For Microsoft Exchange 2007 to PST: Use Export-Mailbox
For Microsoft Exchange 2010 to PST: Use ExportMailboxRequests
For Microsoft Exchange 2013 to PST: Use New-MailboxExportRequest command
Before converting Convert Exchange Server EDB to PST format using PowerShell, Create a separate folder to save the converted PST files from EDB and give any name to the folder. After that right click on the folder which will show you the Properties -> select the Share Folder. Then assign the Read/Write permission and click Share button.
The Shared path example: \\MSServer\new-pst-folder
For Exchange Server 2007
Use below given Powershell commands to Convert Exchange 2007 EDB to PST format.
1: Simply Run the Powerhsell command given below:Add-PSSnapin Microsoft.Exchange.Management.PowerShell.E2007
Then Extract PST file from Exchange Server EDB by using the command given below:Export-Mailbox -Identity abc@expert.xyz -PSTFolderPath \\MSServer\new-pst-folder\Expert-Advice.pst
For Exchange Server 2010 and Exchange Server 2013
Use below given Powershell commands to Export Exchange 2010 and Exchange 2013 EDB to PST format
Run the below given Command:For Exchange Server 2010 – Add-PSSnapin Microsoft.Exchange.Management.PowerShell.E2010For Exchange Server 2013 – Add-PSSnapin Microsoft.Exchange.Management.PowerShell.E2013
Convert EBD to PST by using below-given command:New-MailboxExportRequest –Mailbox Expert-Advice –FilePath \\MSServer\new-pst-folder\\Expert-Advice.pstWhere Expert-Advice is the name of users mailbox that we want to convert in PST file format.
Method 2: Export Exchange 2013 mailbox to PST using Exchange Admin Center (EAC)
Simply use the steps mentioned below to perform the EDB to PST Conversion:
First, you need to create a Shared Folder where you want to export the mailbox. Then Set the Shared and Security level, by clicking on the Permission tab.
Now Assign Mailbox Import Export permissions to the user, follow the below steps to assign the permission.
First you need to open EAC (Exchange Admin Center) then click Permission. After that double click on Recipient Management and click on Add in the top of Role.
Now in the page of Select a Role, you need to click on Mailbox Import Export option -> Add (bottom left hand side) -> OK.
Then click Add in the Roles section and select Mailbox Import Export in a new page. Click Add -> OK.
Once the above process completed Export Mailbox data into PST, to do this follow the below steps:
Open EAC, choose Mailboxes and a list of mailboxes will display. Simply select the mailboxes which you want to export into PST.
Then right click on the mailbox and select Export to a PST file. Click on Browse to select the mailbox and click.
You can find the path of exported mailboxes using syntax: \\MSServer\new-pst-folder\Expert-Advice.pst
The manual methods will discuss to Convert EDB to PST in this blog are:
Method 1: Using PowerShell Cmdlets
Method 2: Using Exchange Admin Center (EAC) or Exchange Management Console (EMC)
Method 3: Using Exmerge Application
EDB is an Exchange Database file, which stores an important mailbox data items such as emails, tasks, calendars, folders, attachments, notes, etc.
General reasons which tends to EDB to PST Conversion:
Sometimes Exchange Server is under Maintenance and the process will take a long time or when the Exchange Server fails to perform any task.
When the organization is migrating exchange server.
Also when user moving/transfer Exchange data from one place to another.
One more reason i.e. Corruption causes In EDB File, to recover corrupt EDB we need to convert into PST file format. The corruption causes due to:
Technical fault in Internet connectivity or abrupt power outage through which Exchange shut down suddenly.
Also due to downtime of Microsoft Exchange Server or unwanted error in the Exchange server like breakdown of Exchange information store, virus attack or hardware failure and many more reasons.
Exchange server has become one of the most widely used great technology in organizations for internal and external communication. When Cached Exchange Mode is enabled, (while configured with Exchange account), Exchange files, holds all the data of your Exchange mailbox on your hard disk in .edb files. And Exchange server synchronizes the .edb file with Exchange mailbox when the server is available. By converting Exchange EDB to PST, you can migrate Exchange server items/files to other platforms, such as Office 365, Live Exchange, etc. An easy method to convert Exchange EDB to PST is to log in to your Exchange server Account for which the Exchange EDB file is created on your system. Now, follow the below steps to convert this Exchange EDB to PST.
If you have a small number of EDB files and you are a technical expert, then you can use a manual solution to convert the EDB file to PST format. But you are not a technical expert and you have a large number of EDB files, then you should check any proficient third-party tool such as Zaplogix EDB to PST Converter. The tool convert files in different formats like HTML, TXT, MSG, RTF, EML, PDF, etc. And with that software is Cooperative with all MS Exchange 2019 and Windows 10 OS version from latest to pioneer. You can check here this tool free trial version: https://www.zaplogix.com/edb-to-pst-converter.html
InQuit EDB recovery application is a master tool to repair corrupted or damaged EDB file which is the best technology to recover all data from orphan EDB file without any error. You can retrieve your mailbox along with emails, inbox, drafts, calendar, contact, attachment etc. without any changes in the previous file. This software gives the correct result with 100% accuracy in a little time after the conversion process. It backing live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016. You can collect your EDB file into PST, EML,MSG and HTML after the exportation process.
Read More: https://download.cnet.com/InQuit-Exchange-Recovery-Software/3000-2369_4-77741909.html
If you want to convert your edb into outlook pst then i want to recommend you to use this edb to pst converter tool. This software also allows you to repair highly damaged EDB file and recover all stored mailbox items within few clicks.
Stella EDB to PST convertert software is 100% safe and secure software .STELLA Exchange EDB to PST recovery software recovered corrupt and damage edb file data without any data loss . You can Easily Download Free Demo Version
Dux EDB to PST converter software is simple and amazing solution to recover damage exchange mailbox data and convert EDB file data into working MS outlook PST file with some different format like as:- EML, MSG, EMLX, DOC, PDF, MBOX etc. This software also support office 365 and live exchange server as well as also divide big size of recovered PST file upto 5GB.
EDB to PST Converter has been proved as an excellent utility which recovers all types of data of Exchange Server such as attachments, messages, calendars, contacts, drafts, tasks, notes, journals, distribution lists, appointments, sent items, completely deleted emails, sub-folders, directories and etc.
For your corrupted EDB file data, not be available a exact solution in online market but Enstella EDB To PST Converter understand Exchange users need and create an ultimate Solution (EDB to PST converter Software) for your corrupted EDB file data. This software easily convert your corrupted EDB file into PST and other multiple formats such as :( PST, EML, MSG, and HTML). It is suitable with all exchange server version from 5.0, 5.5,2000,2003,2007 and 2010 and all windows version (97, 2000, 2002(XP), 2003, 2007, 2010 and 2013 (32 and 64 bit).
Zaplogix EDB to PST Converter tool helps to repair corrupt exchange database, restore all EDB items back into previous format and save into new PST file without any data loss.
use this EDB to PST converter to easily migrate partial and multiple edb files into pst files with ease. It works brilliant and migrate all edb files into pst data with full accuracy. with this tool you can convert all edb files to pst files with its batch conversion option and it also recover all types of data of exchanger server such as attachment, messages, calander, contracts, drafts, tasks, notes, journals, distribution lists, appointment, sent items, completely deleted emails, sub folders, directories and etc.
Enstella EDB to PST converter software which is the best software for your corrupted EDB file to convert very smoothly into PST format without losing any single bit of data such as: (PST, MSG, EML, and HTML) with complete all properties, inbox, outbox, deleted items, email, mailbox, journals, junk mail, subject, attachment, calendar etc. This software has a gives you a demo version which helps to you can easily convert your all EDB file data. It’s suitable for all versions of windows and MS outlook version (97, 2000, 2003, 2007, 2010, and 2013).
SysOZ EDB to PST Converter this program is known for its amazing work that smoothly exports EDB data into PST along with emails, notes, contact, attachment, task, draft, sent item, delete item, journals, inbox, and many more etc. It keeps the data integrity of Metadata like To, Cc, From, Bcc, Subject, Object, Date, and Time. You can easily convert your data into various formats like PST, EML, MSG and HTML.
Bitdataconversion EDB to PST Converter tool is the perfect solution to extracts emails from corrupt Exchange database EDB files and convert Exchange EDB mailbox to PST file. It also supports to export EDB to PST, Live Exchange Server & Office 365 and other save selected recovered email items into multiple email format like EML, MSG, HTML.
For conversion of edb file to different file format you can use dux data recovery exchange edb to pst converter which can convert any edb file to PST,EML,MSG,HTML,EMLX and office 365.Also it can spit edb file large edb file to smaller pst file.
with free version you can recover upto 30 items easily.
Use this another EDB to PST converter software which can easily convert whole EDB data into oultook pst like as emails, contacts, calendars, notes, journal and etc. There is no file size limitation, so the user can easily export any size of edb files into Outlook pst without any hassle. This software can also migrate their corrupted and password protected EDB files into pst.
After that Click Finish, once the process completed.
Convert your EDB file to PST using the MailsDaddy EDB to PST Converter. The tool easily convert EDB file to PST or many other formats without any data loss. It export mailbox items such as emails, contacts, calendars, and other to Outlook PST. It support all Exchange versions.
If you are looking for Best EDB to PST converter, I would like to suggest you to first try the demo version of any software. Because you can check the preview of your mailboxes & take the decision. Stellar Converter for EDB is the best edb to pst converter software which provides the smart conversion facility into different file formats. Provides the facility to migrate large EDB to PST without any file size limitation. Supports all the version of Exchange Server from 5.5 to 2019. Benefits of the software:
1. Helps to save the file in different format. Like HTML, PDF,PST.
2. Gives the preview of Scanned files before the final conversion.
3. Select and export mailboxes from particular range.
4. Allows to easily export the Public folders to PST
5. Provides the option to Directly export to Live Exchange & office 365
Enstella EDB to PST Converter Software repairs damaged EDB File and convert EDB File to PST Outlook file. While using this EDB to PST conversion tool users can convert exchange EDB file to PST, MSG, EML, and HTML format. With completed all Mailboxes, sent items, junk items, contact, calendar, inbox, task, journals, and attachments etc...This Software supports all Windows versions and also MS Outlook version:-7, 2000, 2002, 2003, 2007, 2010, and 2013.
EDB to PST Converter is the perfect way to recover and restore corrupted mailboxes data of EDB files. It can help to export inaccessible EDB data to Outlook PST files. This tool can also help to recover component items such as tables, indexes, functions, etc. User can recover permanently deleted EDB files from any Exchange Server like 2019, 2016, 2013 and earlier versions. You can try the free trial version before using the full edition.
Hey
If you are looking forward for a reliable solution that will help users to perform EDB to PST file conversion, then I am here which one such solution that allows users to convert EDB files into various formats PST, HTML, TXT, MSG, RTF, EML, PDF, etc. The EDB to PST converter permits users to try the demo version of the software as well. So, if you want to explore more about tool then go with the solution.
EDB to PST converter software is the best utility for the exchange edb file conversion. edb to pst converter software support all the version of the exchange edb file. edb to pst converter software convert edb file data into office 365 account also. for more info visit this link, through this Software you can Convert your EDB file to Multiple format like PST, EML, MSG, PDF and HTML formats. This Software also Shows the Preview of all Convertible Mailboxes before Saving.
