urvashi writes:
I am doing a project based on a PLC.
Using the PLC, we will be controlling the water distribution for a particular area. The tank which is to be controlled is capable of handling 10,000 liters of water and it is required to fill other secondary tanks of the buildings.
QUESTION: Which sensor is better for such large tanks?
Will a capacitance level sensor will suit our needs?
or should a level switch be used?
Which one is best suited for use with a PLC?
or are there better sensors for our purpose?
Also, how should priority be assigned to the tanks?
Any further suggestions are welcomed.
Thanks you,
urvashi
