Previous in Forum: How to Convert PST to EML, MBOX, MSG and Other Various Email Format?   Next in Forum: IP66 VFDs
Why Cat 6A Cables Are Considered As Future Proof Products?
04/29/2019 7:27 AM
Choosing the right Ethernet cable is an essential thing to build up a system which is capable to deliver high speed and most importantly on-time data. To do so, it is advisable to choose the current in trend Ethernet products that is Cat 6A cables. These are the high-tech cables with advanced performance standards for twisted pair cable systems. Although, Cat5e and Cat6 Ethernet cables are still in use for installations as they cost less than the Cat6A. When we are heading towards Power over Ethernet (PoE) technology era, Category 6A cables will be the most suited products and are here to stay.
A wrong choice of cables for your system might demand you re-cabling. And according to industry reports, it consumes a lot of time and resources to re-cable the network of an entire building. This way, less expensive products might end up costing you more than its pricing. Instead, you should opt for better quality products as a one-time investment.
Here are some factors which explain why Cat 6A cables are the perfect solution which can be compatible with future technologies and your network systems:
  • Cat 6A Supports The Emergency Transfers
  • High GBPS Delivery Speed
  • Gauge
  • Distance
  • Shielding
Why You Should Upgrade To Cat 6A?
In the future, all phone systems are likely to upgrade to VoIP. And your old cables would not be able to support the new technology. They cannot be compatible with the new speed standards in your systems. Although Cat6A is more expensive than the Cat5e and Cat6 cables, it can be your future solution and will stay longer to fulfill future requirements. Before opting for other relatively cheap options, you should also consider the maintenance value, which might cost you a lot more than the actual Cat 6A cable price. If you go with Cat5e or Cat6, you will need to replace them and upgrade your system sooner.
