Previous in Forum: IP66 VFDs   Next in Forum: Variable Frequency Drives Repair
9 comments
Lotus Notes to Office 365 - Shoviv Software
05/08/2019 4:15 AM
If you want to migrate the Lotus Notes NSF mailboxes to Office 365 and you already use the manual method but you do not satisfy.
Well, so many third party tool available in the whole market but if I suggest, according to my personal experience, I strongly suggest the Shoviv Lotus Notes to Office 365 migration software.
The software, Shoviv Lotus Notes to Office 365 Software is a proper solution to migrate the multiple Lotus Notes mailboxes to Office365, MS Outlook and Live Exchange server proficiently. It also provides the option, with the help of this tool you can export the NSF mailboxes to EML, MSG, and HTML formats. The tool support all versions of Lotus Notes, Live Exchange Server, and Windows OS. Download its free trial version and migrate the first 25 items per folder and check all the functions of the tool.
More details, visit:- Lotus Notes to Office 365 migration
Re: Lotus Notes to Office 365 - Shoviv Software
01/07/2021 7:05 AM
Migration from Lotus Notes to Office 365 manually with IMAP Connector
One can migrate from Lotus Notes to Office 365 or Exchange with the help of IMAP Connector. Below mentioned are the steps for Lotus Notes to Office 365 migration:
Backup NSF files
First of all, backup your IBM Lotus Notes NSF files. In case your migration fails and NSF files get corrupt during the migration, you can recover the mailbox data from the already taken backups.
Create new Mailboxes for each NSF user
Now, create new mailboxes at the Office 365 location (with same name as in IBM Notes) for each user who has an account in IBM Lotus Notes.
Enable IMAP TCP/IP port
You need to enable the IMAP TCP/IP port for each user account. Just follow the upcoming steps to do the same:
Open Domino Administrator in the Lotus Notes Application.
Go to the Configuration tab.
Open the Server document which executes the IMAP service.
Click Ports>Internet Ports>Mail tab.
In Mail (IMAP) column, change the ‘TCP/IP port value status’ to Enabled.
Click the Save button to save the changes and close the application.
Synchronize with IMAP Connector
Finally, use IMAP connector to synchronize mailboxes between Lotus Notes and Office 365. There should not be any issue in the connection now.
I hope this method will be useful while migrating Lotus Notes to Office 365
David Boon
02/16/2021 4:17 AM
In order to import the Lotus Notes file to Office 365, you need to download WholeClear Lotus Notes to Office 365 Migration tool. This application has the capability to import all emails, contacts, journals, tasks along with attachments straight into O365 Account. This program offers a single user interface, which makes it simple to work for all sorts of users. You need to follow these simple steps for NSF to Office 365 Migration.
05/15/2021 2:59 AM
Download the smart DRS
NSF to PST converter tool which is able to export single or multiple NSF files to PST, MSG, MBOX, EML, EMLX, HTML, Gmail, Hotmail, Office 365, etc. The utility is designed on a smooth user-friendly GUI and doesn't require any technical knowledge to run the tool. The free trial version is also available to export initial 50 items per folder for free.
04/26/2022 6:34 AM
Want to export Lotus Notes (NSF files) to your Office 365 account, you can use MailsDaddy Lotus Notes to Office 365 migration tool. It is one of the top-notch migration tools that help to migrate Lotus Notes to Office 365 without risking the data. The tool comes with best-in-class features and a user interface, which gives an immersive experience of working with the software.
You can also use the free demo version of the solution and migrate up to 20 item from each mailbox.
Export Lotus Notes to Office 365
08/27/2025 1:59 AM
Do you want to import Lotus Notes to Office 365? Then try DataVare NSF to Office 365 Converter. Their user interface is simple and easy to use for both technical and non-technical users. It imports a bulk NSF file to the Office 365 Account. It uploads emails and attachments from Lotus Notes to Office 365. Complete error-free processing within a few clicks.
02/03/2026 1:01 AM
I appreciate the explanation and, based on my experience as well, Shoviv Lotus Notes to Office 365 works best for me. The tool has been reliable and effective for migrating NSF mailboxes without issues.
02/13/2026 7:26 AM
Don't bother with confusing file formats. Use the SysTools Lotus Notes to Office 365 Migration Tool, which can directly translate the Lotus Notes server data into the format that Microsoft 365 requires.
What are you waiting for? Find us on Google and start your migration today.
09/16/2026 7:00 AM
Migrating from Lotus Notes to Office 365 feels like moving houses with a broken truck. Every tool promises a smooth ride, but you still end up with boxes everywhere. The thing is, once the data lands, nobody talks about the daily mess. That's where an AI email assistant https://dove.email/ could help, sorting and triaging so you're not drowning in old NSF ghosts. Tools like dove.email seem to get that
10/06/2026 4:28 AM
If you’re moving from Lotus Notes to Office 365, you can migrate the NSF files directly to your Microsoft 365 account. For a small amount of data, you may be able to handle the transfer manually, but it gets messy when there are several NSF files with emails, folders, attachments, calendars, or notes.
For a larger mailbox, Softaken Lotus Notes to Office 365 Migration Tool is one option to consider. You can add the NSF file, check the mailbox data, select the folders you need, and move them to Office 365. It also supports emails, attachments, calendars, notes, and journals. I’d suggest trying one NSF file first and checking the result in Office 365 before migrating everything.
Register to Reply 9 comments
davidboon2813 (1); Kaitlyn Schaefer (1); rajat (1); rajat16 (1); RobbertClaus (1); rowanfletcher (1); SidHeart (1); user-deleted-945 (1); vekebec831 (1)
