Previous in Forum: Absorbed Energy   Next in Forum: Modal Analysis with Ansys classic
20 comments
Good Answers: 143
I need a coupling
10/11/2007 8:53 PM
I'm looking for a small coupling where an inner cylinder or race turns an outer one, but the outer one will not turn the inner one. Sort of like a Bendix bike brake, but the inner shaft is 0.25" diameter.
Re: I need a coupling
10/12/2007 4:00 AM
need.
...more
.......info.
Centrifugal clutch type arrangement? (need to be rather small though?)
What force are you transmitting?
What rpm?
Is it bi-directional?
Shoe size?
Good Answers: 143
10/12/2007 6:55 AM
My reply didn't seem to take.
About 10 in-lb
<10 rpm
small (0.25 shaft)
<$100
bi-directional
10/13/2007 12:40 AM
Bi-directional?
Your earlier statement, "inner cylinder or race turns an outer one, but the outer one will not turn the inner one", contradicts: bi-directional...
10/14/2007 11:06 AM
No it doesnt...
Ineer race will turn outer one...IN EITHER DIRECTION... bi directional.
Outer won't turn inner.
10/14/2007 3:23 PM
unusual type of coupling you have to admit. It took me for a short ride too but then I realised what he meant at first. I have never seen one myself.
If you consider the uni-directional bearings the inner will turn the outer but in the opposite direction from what the outer would turn the inner. Now is that , by some stretch of the imagination, also maybe perhaps bi-directional or not. Can be confusing and leaving you clutching for straws, in any direction if need be.
10/12/2007 6:23 AM
Try asking bearing suppliers for a 'sprag clutch'.
10/12/2007 6:24 AM
You'll have a job doing this in both directions if this drive ever reverses.
Good Answers: 143
10/12/2007 6:52 AM
The sprag only works in one direction, i.e., overunning. Thanks
10/12/2007 7:04 AM
Then you'll need something 'active' like a magnetic clutch I think.
Wish I was here more often.
Good Answers: 143
10/12/2007 8:44 AM
Yeah, I know that's the logical answer. I was hoping for magic. Thanks.
Tom
10/13/2007 12:04 AM
u can try for oldhams coupling .... which v can be fabricated according to ur needs of individual using micro machining.....
10/13/2007 4:04 AM
What is the outer diameter? and how much width is there to play with?
Also useful would be to know what the "ring" thickness could be for either inner and outer.
Personally I have never seen or heard about a ring or clutch type that will transmit rotation in either direction but from the inner to the outer only. Mine always have been uni directional.
Is this a new design or something broke?
Good Answers: 143
10/13/2007 7:01 PM
Sorry to be so vague. The person who wrote the spec thought there was such a thing and I was grasping at straws. Finally convinced him to let me use a spring-loaded multi-tooth coupling; takes an extra step to disengage but, hey, it's available.
Tom
10/14/2007 5:15 AM
That was exactly what I had in mind....I think
10/15/2007 8:09 AM
Perhaps you can help as you are in England. A company called SAMAR TEchnology, 60 Newland Street, Coleford, Gloustershire, UK,GL16 8AL has such a device. Patent numbers UK 2343923 & US 09/434133. I wanted to use one myself for a machine I am building; but I have not yet got a quotation from them.
10/15/2007 10:59 AM
I'll just nip down there.....
10/15/2007 11:06 AM
......wheeze, hhhhssssshh, gasp.....
Came back with this http://bdmclient.co.uk/docs/SamarTec.pdf
Seems like someone has found a way to re-patent something (a sprag clutch by any chance??)
10/15/2007 11:16 AM
I can sell you some 7 league boots ? Would considerably speed up any similar juorneys.... to Coleford, Gloustershire Puss ! (Slaps thigh)
10/15/2007 12:55 PM
As it is over 100 miles away for me, I can't just nip over there I am afraid. Hope one of the other guys have been of help but if you need anyting else on it just repost and we will see what we can do.
10/15/2007 11:53 AM
TRY THESE GUYS
https://sdp-si.com/eStore/
SEARCH FOR CLUTCH
Register to Reply 20 comments
Anonymous Poster (2); Capt Psycho (1); case491 (4); rao.vasuki (1); TVP45 (4); user-deleted-1105 (3); Wrenched (3); Yanthram (1); yesyen (1)
