Previous in Forum: Magnetic Actuator Circuit Breaker?   Next in Forum: planar transformer
Calculating Induced Voltage in a moving coil through a static field.
10/13/2007 12:06 AM
The problem stated.
What is the algebraic equation for induced voltage of a coil moving at known velocity in m/s through B in Tesla's at the optimum induction angle?
Gavilan
Re: Calculating Induced Voltage in a moving coil through a static field.
10/13/2007 7:30 AM
90 degree nodoult
V=b2pirvcos(xita)
10/14/2007 2:41 AM
Sir
Can u please Explain me the Equation mentioned above.
Thank You
Ramana.
10/15/2007 5:10 AM
It is the algebraic equation for induced voltage of a coil moving at known velocity in m/s through B in Tesla's at the optimum induction angle.
10/15/2007 1:22 PM
Could someone define the variables in the equation.
I don't see a variable for inductance?
10/15/2007 9:03 PM
If the magnetic field is uniform. the voltage is only simple
V=vB2rcos(xita)
no relation with turns.
10/15/2007 11:42 PM
So you are telling me that a coil with 2 turns moving at V through B will have the same induced voltage as a coil with 200 turns moving at V through B?
How about v=BLV? where B is in Tesla's L is in Henry's and V is in meters per second?
Gavilan
10/16/2007 6:41 AM
they equal to parallel form
with regard to v=BLV
L is length in meter, not inductance in herry.
would you pls refer to electromegnatics or static electrics?
Register to Reply 7 comments
Anonymous Poster (1); cnpower (3); Gavilan (2); Ramana (1)
