Previous in Forum: 24 switches, 24 Led's, 200ft away   Next in Forum: harmonics
nuetral
10/13/2007 7:57 AM
what is the use of nuetral in electrical field
Good Answers: 266
Re: nuetral
10/13/2007 10:31 AM
To provide a path for current flow.
Egypt - Member - Ahmad Samak
Re: nuetral
10/13/2007 6:41 PM
To provide a path for current flow in single phase loads.
Re: nuetral
10/14/2007 11:31 AM
Transformer Neutral provides return path to unbalance current in the system
Re: nuetral
10/14/2007 7:23 PM
Hello asdabh,
It is not necessary for unbalanced load (and hence, unbalanced current) to have return path.
Unbalanced loads can be operated under a condition of 3-phase 3-wire systems, however the natural result is a shifted neutral point of which is not connected to the load.
Regards
Samak
Re: nuetral
10/16/2007 12:18 PM
Dear Samak
Origional question was "what is the use of neutral in electrical field ".So Iwas assuming 3ph & 4 wire system & tried to reply. Will you pl give correct reply now?
Regards
Re: neutral
10/16/2007 6:00 PM
Unbalanced load current can be returned to the supply via the three line wires, resulting in supply's neutral point to be shifted away from the origin (zero volt).
Only a single phase load needs a return path to operate, such a path must be the neutral wire.
Re: neutral
10/17/2007 9:59 AM
Thanks .nice reply.
Regards
Register to Reply 7 comments
asdabh (3); ozzb (1); Samak (3)
