Previous in Forum: Can't Install Skype   Next in Forum: Domain Names - Buying and Selling
11 comments
Joe 6 Pack Explanation Needed for These Terms
06/07/2019 7:02 PM
Simple language and/or examples.
This has to do with a Geotextile material that will be used for liner in a huge Fish pond.
What is:
Grab Tensile strength
Hydrostatic Resistance
Tounge Tear Resistance
Re: Joe 6 Pack Explanation Needed for these terms
06/07/2019 7:29 PM
Hydrostatic Resistance....how much water weight it can hold without seeping through the fabric
Grab Tensile strength.....how much force it takes to break the fabric
Tongue Tear Resistance.....how much force it takes to tear the fabric
06/07/2019 7:40 PM
Thank you....I may have other related questions once I get nearer to a design for this. thank you as usual.
06/09/2019 10:38 AM
Those are joe 6 pack explanations before joe drinks the 6 pack. After joe drinks the 6 pack, the answers will be completely different.
06/07/2019 7:42 PM
hydrostatic resistance is 369 psi. ….. means 369 pounds per every square inch?
Given a pond shape of 100' x 100' x 30' deep.....will this liner hold water?
06/07/2019 7:48 PM
30' is 360 inches ...1 cu inch of water weighs 0.0361 lb....times 360 equals about 13 lbs...
Water resistance for fabric is generally for raincoats and is measured in psi...
Waterproof fabric is generally measured in mm of water, like 10,000 mm of water without leaking....
https://www.getoutwiththekids.co.uk/family-tents/hydrostatic-head/
06/07/2019 7:52 PM
Thank you....its a "GO" !
06/07/2019 10:06 PM
Good Answers: 120
06/08/2019 8:42 AM
Some fabrics, like Goretex allow air to pass and block water by a non wettable woven grid, others have a continous block that will not pass air or water. I assume a pond needs to continuous block. If the fabric and the blocking agent will not rot or be attacked by soil bacteria, in an underground milieu it will last a long time, failure will be by assorted holes, of whatever size that gradually increase the leakage cross section to the maximum allowable leakage.
Permanent membranes for this use are usually dacron or nylon or other synthetic densely woven fabric that has one or more impervious and continuous layers of a synthetic rubber or plastic. The woven fabric must be strong enough to withstand the weight the cloth must bear and the sealing layers must resist the hydrostatic pressure. Often they are made in several layers and the crossing angles vary to make sure there is no weak direction along which it can tear. The bed in which is laid is also tamped and pack to make sure there are no voids to collapse or any sharp pointy things that can pierce to make sure there will be no leaks for decades - more time = more $$.
Per Ardua Ad Astra
06/09/2019 5:12 AM
And it all works very well until the wading birds think there is something under the fabric at water level and punch holes through the fabric lowering the water level and the whole process repeats itself.
Had it happen to turkeys nests, colloquial name for above ground ponds, in the desert, for they just loved to explore the underside. Good luck with your endeavours.
Hare today, goon tomorrow!
06/09/2019 12:21 PM
I believe this is only for temporary use...short term....
https://www.hcn.org/issues/47.7/tucsons-rain-catching-revolution
06/09/2019 8:11 PM
I see a job opportunity for me on top of that house.
Register to Reply 11 comments
aurizon (1); netmaker (3); SolarEagle (4); Stef (1); tonyhemet (2)
