Previous in Forum: A Brief History of CO2-Related Climate Change   Next in Forum: What is Information?
36 comments
Good Answers: 54
New Project - Epoxy That Conducts Electricity
06/16/2019 3:23 PM
Happy Father's Day to all the dads out there!
I was at one of my rentals yesterday and I noticed the remote for the ceiling fan wasn't working. It uses a CR 2032 lithium cell, so I opened the cover and the cell + the holder came out. The holder was soldered to the circuit board. It's a piece of spring metal that's chrome plated. It holds the cell in place and it gently pushes it to the circuit board.
The cover is very small and there's no way to get a soldering iron to the terminals. The two halves of the case are glued together and I don't want to take it apart. So, I was thinking of using a conductive epoxy or glue to hold the battery holder to the circuit board.
My questions are:
1. Has anyone had success with a product like this?
2. Longevity?
3. Is there a fast drying glue - something like a "Krazy Glue" type product.
I can replace the remote for around $40, but I'd rather fix it. So I'm looking for an inexpensive product.
Any recommendations are greatly appreciated.
Thank you.
Re: New project - epoxy that conducts electricity
06/16/2019 4:01 PM
This should work....these can be fairly expensive, but then it's possible you may find more than just the one use....this was the cheapest I could find ...
https://www.amazon.com/Electrically-Conductive-Adhesive-Temperature-AA-DUCT/dp/B00EPYCIGQ
Good Answers: 54
06/18/2019 7:45 PM
Thanks Solar. I think the repairman in me wants to fix it vs replacing, however I can get a new remote for $15 - I'm thinking that may be the smartest thing to do.
Thanks again.
Good Answers: 11
Re: New Project - Epoxy that Conducts Electricity
06/16/2019 11:03 PM
Maybe research Devcon metal putties et al e.g. "Plastic Steel Putty (A) – For filling, rebuilding and bonding metal surfaces". They used to have aluminium products in the 70's - over to you.
Cheers
Malcolm
Good Answers: 54
06/18/2019 8:33 PM
I took a look and it doesn't say if it's electrically conductive. Have you ever used it for electrical connections?
Good Answers: 11
06/19/2019 8:44 AM
No, sorry. I've only used it for cosmetic metal repairs, usually on damaged castings way back - it was pretty much the last card in the pack.
Plenty of other good suggestions on this thread by others to go on.
Good luck.
06/21/2019 2:35 AM
Epoxy is a liquid plastic. Most plastics are not conductive. I'm sure there are exceptions, but this would not be the norm.
06/16/2019 11:32 PM
I think you'll have better luck looking for an appropriate cement to glue the two halves of the case back together (depending on the kind of plastic). The solder points are presumably on the back side of the circuit board, and may well be oxidized/corroded from a leaking battery in the past. If so, there is no guarantee that you'll be able to make contact between the conductive cement and the circuit board and the battery holder parts.
Crack the two halves apart, clean the circuit board and the battery holder parts, properly re-solder the battery holder parts in place (paying attention to polarity and spring position), insert the battery, and glue the case halves back together.
The battery holder MUST consist of two separate parts. Upon re-reading your text, it sounds like only one of those two parts (the spring part) came out. If it is really chrome-plated, you may have to sand, file, grind the chrome off at the solder end before soldering it. It is virtually impossible to solder to chrome. To be sure, tin (coat with solder) the solder end of the spring before attempting to solder it in place. If you can't get the solder to coat the metal, then it won't make a reliable contact and will likely fall out again.
Good Answers: 54
06/18/2019 8:27 PM
Hi DK,
I was hoping for a quick fix. The battery didn't leak - the solder broke from probably a bad original solder and my tenant trying to change the battery. Looking at the circuit board, it looks like it was a cold solder (that cracked metal look).
I heard about conductive epoxy, so I thought I'd give it a try. I have this need to fix vs replace, so I was hoping it would be an easy repair. I can get a replacement for $15 - I think that'll be the best option, though I'm going to read the other responses.
Thanks.
06/18/2019 8:52 PM
Your assessment sounds accurate. Cold solders have become much more common since they took the lead out of most solder.
By "I have this need to fix vs replace", I suspect you indicate a desire to avoid waste, and I'm definitely in agreement with that!
Obviously, you've spent more in your time writing and reading these posts than the value of the new unit. As someone else said, you have nothing to lose if it does not work, so go for it! I'm definitely not a fan of epoxy to support a spring that is under constant tension.
Good Answers: 54
06/18/2019 10:17 PM
Thanks DK.
I hate throwing something out that can be fixed at a reasonable cost and time - comes from lessons from my dad. For the 21st century problems, I know it isn't going to make a difference in the world, but when I can do my share to reduce waste at a landfill and buy one less item made in China, I feel better about it. And you're right, I've spent more than $15 of my time to type up this thread and to respond.
Since the remote works (when I hold the battery and holder down), I'm willing to give things a try. I'm not a fan of gluing things together, but that may be the best option. Or soldering with a copper wire on the tip of the iron?
06/19/2019 12:37 AM
One little hint: Assuming you have a fairly large soldering iron with a mostly cylindrical tip, and you want to use the idea of wrapping a copper wire around it with the end sticking out as a fine tip, use as large a wire as possible (something like size 8-10) that will fit the space required. and find a rod with a slightly smaller diameter than the soldering iron tip. Wrap the wire tightly around that smaller rod, so you have to force the coil on to the soldering iron, to get tight fit and thus best heat transfer.
Copper does not spring back as much as many metals, but it does spring back a little, so you won't get a tight fit by directly winding tit around the soldering iron tip.
Good Answers: 54
06/19/2019 2:48 PM
I have a cheapie soldering iron with a pointed tip. The copper wire should be able to transfer enough heat to get the solder to melt. My first thought is to try the conductive epoxy, but I know if it doesn't work, it'll be very difficult to clean the board and solder. So if it fails, I'm going to just buy a new remote.
I'm checking this site to see if someone has used the epoxy with success.
Thanks again for the tips. It's greatly appreciated!
06/17/2019 3:53 AM
If you have more patience than money,fix it.If the two halves of the enclosure are not glued,they can be gently and slowly pried apart.If they are glued,use a scalpel that is heated to cut the dividing line,then use a super glue to reassemble.As mentioned elsewhere,cleaning and prepping the electrical parts before attempting to join them is essential.Minimize the time of contact between the board and the soldering tip to be certain to remove all traces of flux after soldering to prevent lifting the traces on the board.
If you are not competent and experienced with soldering techniques,the board will be destroyed beyond a reasonable repair.I have replaced broken traces on some boards,but it was a mission critical application with no spares available.It requires a very steady hand and special tools,no caffeine,and sometimes a magnifying glass.The newer surface mount components are nearly impossible to repair or replace.
Good luck.Even if you don't fix it,it will be good experience.
What have you got to lose?It doesn't work now,right?
Good Answers: 54
06/18/2019 8:30 PM
Thanks for the encouragement.
I've done a lot of soldering, so I'm not concerned about that aspect. I just didn't want to spend the time to take it apart, then have to reglue it back together again.
In the post above, I stated I can get a replacement remote for $15. I just wanted to fix the old one. Seems better to buy a new one.
06/17/2019 5:43 AM
ci139
Good Answers: 54
06/18/2019 8:33 PM
Thanks for the info. I've never heard of a product like this. I don't think it'll work in such a small area, but I have another use for zinc spray - anti rust coating!
Thanks again.
Re: New Project - Epoxy That Conducts Electricity
06/18/2019 3:31 AM
I have not tried to use the particular product mentioned but I did try using silger conductive paste between the contact and circuit board and holding in place with epoxy resin. Was not a success as the epoxy wouldn't stick to the circuit substrate even when sanded rough.
This was on a digital caliper so I was able to open the case by gentle prising with a screwdriver as there had only been spots of glue not fully glued. The contact was nickel plated but the plating had detached from the base of the spring clip exposing steel which was pitted. There has never been a battery leak in the holder so it must have been shoddy manufacturing. So I made a new one out of bronze and soldered it in place.
If you go down the road you intend to I wish you luck.
Hare today, goon tomorrow!
Good Answers: 54
06/18/2019 8:36 PM
Interesting idea. For me, it'll take too much time to make a new battery clip out of bronze. If it was an expensive remote, that would be an idea.
Thanks.
06/21/2019 2:37 AM
Good Answers: 54
06/21/2019 2:44 AM
Good Answers: 32
06/18/2019 4:48 AM
Not an epoxy fix but wrapping a copper wire around he end of a soldering gun tip then leaving a short length sticking straight out, 3/4", would give an extension with enough heat to solder that part.
Using a thin super glue to rejoin the remote cases can be done more neatly using a toothpick to apply small amounts accurately along the seam.
Success!
06/18/2019 6:19 AM
If it was me, I would try to adapt the soldering iron by wrapping a piece of copper wire tightly around the tip to make a short extension, just long enough and thin enough and shaped, to get in the narrow space between components to reach the broken terminal ... but subject to advice by others to make sure the terminal solder surfaces are very clean to start with.
Good Answers: 54
06/18/2019 8:39 PM
Kendall and Horace. Thanks for the idea. I think I could get a piece of copper wire in the right place to get the solder to work. A very good idea - thanks!
06/20/2019 4:54 AM
If you have access to a lathe you could bore a hole in the soldering iron tip and use a piece of 1.6mm 50% Silver solder to extend the tip. Silver solder is a great conductor of heat, it is rigid and won,t tarnish. I have used this to solder PGA and surface chips when a leg needs to be resoldered.
I have used a coating of silver solder on soldering iron tips to make it easier to accept the solder for tinning especially on the temperature sensing types which erode and lose the ability to be wetted by solder.
Good Answers: 54
06/20/2019 4:15 PM
That's a good tip. I've never thought about coating the tip of my iron with silver solder, but it makes sense.
Next time I pull the oxy/acetylene tank out, I'll coat the tip of my iron.
06/18/2019 2:27 PM
I don't know if there is any strength or not but there is glue to fix rear window defroster that I have considered using for this type repair. I haven't tried it though.
Good Answers: 54
06/18/2019 8:50 PM
Thanks for the idea. I think they sell the stuff at the 99 cents store.
Good Answers: 54
06/18/2019 8:54 PM
Thanks everyone for the tips.
Here is some information and another question.
1. The remote works when I hold the battery and the holder in place.
2. It does not work when I put the cover on - the cover doesn't hold the battery and holder in place.
3. The solder seems to have been a cold solder - broke from physically pulling up and poor adhesion.
4. I can get a replacement remote for $15, but the repair guy in me wanted to fix it.
5. A couple guys mentioned wrapping wire around a soldering iron and using the wire as a heat source. I may do this.
6. I found this stuff on ebay. Has anyone ever used it? It's a cheap conductive adhesive. https://www.ebay.com/itm/0-2ML-0-25ML-0-3ML-0-5ML-Silver-Conductive-Adhesive-Glue-Wire-Electrically-Condu/303188093143?hash=item46976b28d7:m:mgvRZH4mxhX9sxzRLrep6uA
Thanks again for your input.
Good Answers: 11
06/19/2019 8:57 AM
Re: "I can get a replacement remote for $15, but the repair guy in me wanted to fix it."
Good on you, what've you got to lose. You should have seen the trouble I went to to rebuild a brake light socket on my 97 BMW M3 (a bit of a notorious fault) - I've surprised myself with it still working ~5 years later!
Also, we all learn something and I like the look of that "conductive adhesive" for a future project.
Cheers
Good Answers: 54
06/19/2019 2:51 PM
Your '97 M3 is a nice car! I almost bought a high mileage 1998 M3 a couple years ago. It had 240K on it - looked pretty good, but it had a smog problem, so I passed. It wasn't abused - driven, but not abused. In hindsight, I should've bought it. Price was very, very reasonable, due to the miles and CEL.
Good Answers: 11
06/20/2019 5:06 AM
Interesting coincidence!
It looks like you're US based, so may mention (in case you're not aware) that here in Australia, we were lucky enough to get the European version with full 321 hp (3.2L). They're really starting to go up in value here (and the UK to my knowledge). Not sure if the US version has had the same increase.
Cheers
Good Answers: 54
06/20/2019 4:12 PM
321 hp! Nice!! We only get the 240 hp version. Still a very sweet car, but I can only imagine another 81 hp out of that straight 6.
I've delivered some newer M3's and they're beasts. The latest iteration (2018 M3 CS) put out 453 hp - 3.0 twin turbo straight 6. I drove the regular version (not the CS) and it's so fast. Too much for my brain to handle!
My personal favorite car (for going fast) is a Porsche 911 or Cayman. They're phenomenal to drive and they are durable - as long as you treat them well. Because they're so well balanced and they rotate so well, driving one at speed makes you a better driver. I don't want to admit it, but the it's the car, not me.
Lately, I've been on an Alfa Romeo kick. I like the older (up to '74) Spiders. They aren't fast by today's standards, but they have such a great feel and the little 2L twin cam is such a wonderful motor. I haven't driven a '71 with the smaller 1750 motor, but I heard it's nearly as fast and it's a more durable design.
Good Answers: 11
06/21/2019 5:04 AM
You appear to be channeling me! For a large part of my adulthood, I wanted an Alfa GTV (and to only a slightly lesser extent, a Spider). My head always seemed to overrule my heart though.
Cheers
Good Answers: 54
06/24/2019 2:45 PM
I saw a GTV on the road a few days ago. Yellow one, my guess is early 70's model. It sounded great and had that super cool look!
The problem is that a nice one is in the $40K + range. For that kind of money, I think there are better buys out there. Like a Porsche 993, Alfa 4C or maybe a low mileage 1990's Ferrari!
On a different note, the mid 70's to early 80's Alfetta GTV may start to take off. This one is a 1977, looked nice and sold for $5K earlier this year. https://bringatrailer.com/listing/1977-alfa-romeo-gtv-3/
It's one of detuned 2.0 twin cam motors, but it's an Alfa with a real Alfa motor. $5K is nothing for a piece of Alfa history.
Good Answers: 11
06/24/2019 9:06 PM
Yeah, 105 GTV's are pulling good money here too. They always won my heart on appearance, sound and handling, but never made it to my garage due to rust, reliability and driving position compromises.
The Alfetta looked like a bargain. FYI, 3 x 4 cyls on the (much smaller) Australian market at ~$AU14k, 17k & 30k; with 5 x V6's $AU 25 - 47k.
I have a friend with a 4C - awesome performance and looks, although I struggled to fit my (day) backpack into the boot (trunk).
Personally, I'm a big fan of the E92 M3 (V8) and I think good buying now, while a Cayman S would be my 2 seater choice in the price range.
Cheers
Good Answers: 54
07/08/2019 2:32 PM
I'm starting a new thread for a trip I'm doing next week in a 1973 Alfa Spider. It's a cross country road trip. Watch for the post sometime today - depends on my work schedule.
Register to Reply 36 comments
Autobroker (17); byrom (2); ci139 (1); dkwarner (3); harley (1); HiTekRedNek (1); horace40 (1); kendall (1); Malcolm Stephen (6); SolarEagle (1); Stef (2)
